75-76 Wire Harness Tape, Here's What I Did |
914Sixer |
Jul 12 2019, 05:44 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
75-76 cars use vinyl tape, NOT the cloth tape used on earlier cars on the wire harness. Factory tape is about 12 mm wide. The closest I could come up with is 3/8" tape that is almost 10mm wide. Side by side you can see a small difference. I stripped off the old factory tape and cleaned up the wires and re-taped the harness. I used a about the same gap as best I could. The difference is not noticeable when you do the whole run. I forgot to get the harness pictures but I will post them tomorrow. Posting pictures of tape side by side.
Sidebar note: I have 4 rolls of tape that will be freebies if someone wants them for the shipping. Attached image(s) |
edrotol |
Jul 12 2019, 05:50 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
75-76 cars use vinyl tape, NOT the cloth tape used on earlier cars on the wire harness. Factory tape is about 15 mm wide. The closest I could come up with is 1/2" tape that is almost 13mm wide. Side by side you can see a small difference. I stripped off the old factory tape and cleaned up the wires and re-taped the harness. I used a about the same gap as best I could. The difference is not noticeable when you do the whole run. I forgot to get the harness pictures but I will post them tomorrow. Posting pictures of tape side by side. Sidebar note: I have 4 rolls of tape that will be freebies if someone wants them for the shipping. I'd like to purchase the 4 rolls. Zip is 01801. Let me know the cheapest, thanks. |
914Sixer |
Jul 12 2019, 06:01 PM
Ad is over in the Classified. Shipping will be $6 for all 4 rolls.
914Sixer |
Jul 14 2019, 05:27 PM
Got front and rear done. Removed dash for rehab and redid dash wiring.
Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:11 AM |
