Push rod tube O rings.... |
MikeM |
Jul 31 2019, 08:22 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...are the O rings in the Victor Reinz gasket set acceptable?
Are they Viton? They are green if that matters... Thanks |
injunmort |
Jul 31 2019, 08:30 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
they work for me
dr914@autoatlanta.com |
Jul 31 2019, 09:51 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the viton ones are black, but the green work just fine with the limited number of miles we are now putting on our cars: HOWEVER, as labor is expensive to change them and the viton seals are not very much money, I would CERTAINLY install them rather than the green or rust colored originals
MikeM |
Jul 31 2019, 10:14 AM
Thanks, as always....
IronHillRestorations |
Jul 31 2019, 11:48 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've seen viton seals I wouldn't use, poor quality with flashing. If your green ones are from a Victor Reinz kit, I'd use them, just don't goop them up with RTV.
I use a very thin smear of Loctite 565 on the seals just before putting them on the tubes, and then install right away. |
get off my lawn |
Jul 31 2019, 01:38 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
Viton is Ok with motor oil, but not great. it can't take heat pretty good too.
Buna N is preferable for this application and probably what you have in them green things. Neoprene would last about 2 minutes, that stuff is pretty much only good for water. Teflon is great for chemical rresistance but doesn't have much memory (spring back) and can cold-flow so would only be good for a little while. The best would be a perfluroelastomer like Kalzez or Chemrez but they would cost $100 each or more. Wait where was I? Oh yeah, Buna N. good. |
einic |
Jul 31 2019, 02:17 PM
Newbie Group: Members Posts: 49 Joined: 28-May 10 From: Norway Member No.: 11,773 Region Association: Scandinavia |
Viton with no[b] sealant
Highland |
Jul 31 2019, 10:02 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Are the pushrod o-rings standard size 212 and 214 or are they a custom size?
porschetub |
Jul 31 2019, 11:47 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yep gluing them in will cause leaks as the engine grows as it expands and cools,clean fit and some oil on them is the trick.
Used to glue in the T1 seals but that's a very different setup. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:14 AM |
