The Brazilian made thermostat, anyone used them and do they fail ? |
porschetub |
Jul 31 2019, 11:20 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have read about these as having no fail safe,wondering if they are reliable,I see George is selling them but general feedback is they aren't worth the risk,comments from those who have used/sell them would be a help,however need to know if they are reliable.
I know nothing about them and that's the reason I'am asking. TIA |
Beebo Kanelle |
Jul 31 2019, 11:34 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Got this one and never looked back
http://awesomepowdercoat.com/Porsche_914_t...stat_parts.html |
porschetub |
Aug 1 2019, 12:35 AM
Yes been there thanks and then there is the Chinese ones too !!.
dr914@autoatlanta.com |
Aug 1 2019, 08:17 AM
914 Guru Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
small modification of the bracket needed but work great. Wheeler Dealers had a small video on installing when they did the 914 several years ago
malcolm2 |
Aug 1 2019, 09:12 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I am with you. They do good work and have everything you need. I have heard that when the non-OEM ones, with the spring, fail, the flaps stay closed. The OEM accordian fails and the flaps stay open. Safer to be open, right? Not sure about the failure rate of either. |
mepstein |
Aug 1 2019, 09:32 AM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I am with you. They do good work and have everything you need. I have heard that when the non-OEM ones, with the spring, fail, the flaps stay closed. The OEM accordian fails and the flaps stay open. Safer to be open, right? Not sure about the failure rate of either. I think “wheeler dealer” incorrectly stated that the engine was overheating because of the failed thermostat. It was a fun episode but not all that truthful. |
tvdinnerbythepool |
Aug 1 2019, 09:56 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
I installed the Awesome Powdercoat thermo per the recommendation of guys here. Works very well, but it did take about a month as they were backed up when I ordered.
porschetub |
Aug 2 2019, 01:53 AM
I am with you. They do good work and have everything you need. I have heard that when the non-OEM ones, with the spring, fail, the flaps stay closed. The OEM accordian fails and the flaps stay open. Safer to be open, right? Not sure about the failure rate of either. Yep know all that thanks, presume they are just a bi-mental spring which could wear out in the end,then you could say "oh I have a temp gauge" but (IMG:style_emoticons/default/WTF.gif) do you do when it fails ...no tools ,pissing down with rain @ and midnight and no torch for example. Currently looking @ repop original,will report back. |
Lo-Fi Version | Time is now: 16th June 2024 - 11:39 PM |
