mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,902 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I want to remount my seatbelts in my car and since the car was apart when I got it they are fully retracted.. How do I get them to move outward again?
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
bolt the retractor down first, it'll let go then
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
The belt will only release if the retractor is orientated correctly, gravity is required.
mb911 |
Oh gotcha. Had no idea . Thanks.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Some interesting seatbelt info :
https://914electric.wordpress.com/2011/09/2...elt-tightening/ I freed up the belt using their recommendation... (IMG:style_emoticons/default/smile.gif) |
Garland |
And easy way to clean them up is in hot soapy water. Lower the whole mechanism into the bucket run it back-and-forth dry thoroughly. Trying to unwind the mechanism, and then reset it is troublesome.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
the cleaning is very important, and then you can pull the belt out all of the way and lubricate the bobbin for smooth operation
And easy way to clean them up is in hot soapy water. Lower the whole mechanism into the bucket run it back-and-forth dry thoroughly. Trying to unwind the mechanism, and then reset it is troublesome. |
mb911 |
Gosh do I feel stupid. Thanks to the recommendations from everyone they are out and working. Thank you.
Lo-Fi Version | Time is now: 16th June 2024 - 04:52 PM |
