| dt4 |
Sep 3 2019, 11:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England
Hi
Could someone advise if the front screen trim is polished stainless steel or chromed please Mine is scratched and just wondering if is polishable Thanks |
| dt4 |
Sep 3 2019, 11:57 AM
| beech4rd |
Sep 3 2019, 12:45 PM
Member ![]() ![]() Group: Members Posts: 348 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States
It's an anodized finish. You can polish it. If you do so, you will remove the anodizing and it will tarnish, requiring that you polish it again and again. It does look a lot more shiny when polished, though. The only way to return to the original finish is usually to replace the trim with new. I believe it's still available from your local Porsche dealer. Chris |
| dt4 |
Sep 3 2019, 01:20 PM
thanks Chris, do you know if it comes out separately to the wind screen or does the glass have to come out?
| mepstein |
Sep 3 2019, 01:25 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,534 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| Chi-town |
Sep 3 2019, 01:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Clear anodized aluminum
You have to strip the ano before you can polish it |
| dt4 |
Sep 3 2019, 01:41 PM
thanks Chris, do you know if it comes out separately to the wind screen or does the glass have to come out? comes out separately. Buy a trim remover and watch youtube videos on how to remove. i have the trim removal tools, I will track down the how to video, thanks |
| dt4 |
Sep 3 2019, 01:42 PM
| Mikey914 |
Sep 3 2019, 02:28 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Basically you can wet sand and polish it. If you use a 2 stage wax with a polish sealer it will last outside for quite some time. The trick is not to deform it while polishing. A 1000 or1500 grit would be a good start finishing with a 2000.
If you need new I can help out, but looks salvageable. |
| dt4 |
Sep 4 2019, 12:35 AM
Basically you can wet sand and polish it. If you use a 2 stage wax with a polish sealer it will last outside for quite some time. The trick is not to deform it while polishing. A 1000 or1500 grit would be a good start finishing with a 2000. If you need new I can help out, but looks salvageable. That's really useful, thank you. I'll give it a go. I am building a list of the parts I need to order from you so if it goes Pete Tong I can add these to the list |
Lo-Fi Version | Time is now: 12th March 2026 - 04:02 PM |
