| 9**P-car |
Sep 11 2019, 12:45 PM
1975 2.0L ![]() Group: Members Posts: 17 Joined: 11-September 19 From: Virginia Member No.: 23,450 Region Association: MidAtlantic Region |
Hello folks. I’m a new member here. I am having a shop perform a PPI on a 1975 2.0 that I am looking to purchase. They can’t find the engine serial number. Isn’t it located on top of the engine, in front of the oil filler neck? Thanks.
| ndfrigi |
Sep 11 2019, 12:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,983 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
| 9**P-car |
Sep 11 2019, 01:03 PM
Thanks for the Pic! On this car, that metal area is smooth - no numbers stamped. From what I have read, it may be a replacement block that doesn’t have a number.
| ndfrigi |
Sep 11 2019, 01:18 PM
| mtndawg |
Sep 11 2019, 05:59 PM
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None
| 914werke |
Sep 11 2019, 07:50 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
if not a replacement case a transplant from 912e ?
| ndfrigi |
Sep 11 2019, 08:00 PM
is it F.I. or carb? can u share pic of ur engine?
| porschetub |
Sep 12 2019, 01:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,117 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
is it F.I. or carb? can u share pic of ur engine? (IMG:style_emoticons/default/agree.gif) ,would really help,have the numbers been ground off or is the area smooth as it would be cast from the factory. I would certain get your guy to check that. |
| 9**P-car |
Sep 12 2019, 03:46 PM
The first 2 pics are from the dealer selling the 914. The 3rd pic is from the mechanic performing the PPI. That area where the number should be is smooth.
Attached thumbnail(s) Attached image(s)
| davep |
Sep 14 2019, 02:06 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,363 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If a 912E engine, the serial is located on the fan shroud. If a normal fan shroud is placed on a 912E case, then there would be no engine serial to be found.
| 9**P-car |
Sep 14 2019, 06:05 PM
Mystery solved. I was able to track down the original owner, and he said he threw a rod in 1979, and had to get a replacement block. Thanks for everyone’s responses.
| bobboinski |
Sep 14 2019, 08:12 PM
Member ![]() ![]() Group: Members Posts: 200 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California
Mystery solved. I was able to track down the original owner, and he said he threw a rod in 1979, and had to get a replacement block. Thanks for everyone’s responses. I've never thought about this before but why would a replacement block not have a serial number? If a dealer had the proper stamps (or whatever you call them) I guess they could match the new block to the old engine number? |
Lo-Fi Version | Time is now: 9th June 2026 - 08:01 AM |
