F/S Early style outside door mirror-fair condition- $25 shipped, Driver quality early door mirror...SOLD....... |
reharvey |
Sep 12 2019, 09:33 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
I've tried to show the flaws in the photos. Glass has a dark shadow along the bottom and there are some dings/scratches. $25 shipped to the lower 48
Attached thumbnail(s) |
mepstein |
Sep 12 2019, 10:10 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'll take it please. Thanks, Mark
Superhawk996 |
Sep 12 2019, 10:29 AM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/av-943.gif)
Where’s the warehouse? I’ll eventually need one but you’ll have cornered the market by then. |
johnhora |
Sep 12 2019, 03:34 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Yes Mark...will you please leave a few for us to get (IMG:style_emoticons/default/biggrin.gif)
Damn you must have at least 500 of the early type already god knows how many later type you have.... (IMG:style_emoticons/default/biggrin.gif) |
Superhawk996 |
Sep 12 2019, 04:52 PM
mepstein |
Sep 12 2019, 05:17 PM
Yes Mark...will you please leave a few for us to get (IMG:style_emoticons/default/biggrin.gif) Damn you must have at least 500 of the early type already god knows how many later type you have.... (IMG:style_emoticons/default/biggrin.gif) Only two later ones. Saving them for my suby car. |
mepstein |
Sep 12 2019, 05:36 PM
I’m waiting on some inner spacers from 914rubber. Mark said it will be a couple months. While the outer trim rings seem to hold up great, the white inners, especially the early ones, turn into dust. It’s also surprising how many decent mirrors you need to make one good one. Problems: Someone used a screwdriver to pry off the trim ring and cracks the edge Someone tries to adjust the mirror when it’s corroded tight and the inner washer makes a bulge in the stainless cover. Rock strikes to the stainless cover. The large triangular washer inside the mirror is cracked or broken in half The chrome is chipping or corroding on the arm. It can take two or three mirrors to make a good one. The ones that won’t work for a restoration (dented backings, peeling chrome, etc) I will probably powdercoat in black. So once I get some inner spacers I will build up a couple to offer up. |
Literati914 |
Sep 12 2019, 05:51 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I actually saw this one first.. but passed on it 'cause I figured Mark might be interested. (IMG:style_emoticons/default/poke.gif)
Superhawk996 |
Sep 12 2019, 06:10 PM
Mark,
Whatever you do, don't throw out the ones with rock dent in the stainless cover. That can be metal worked out and polished. Can be made nearly undetectable in most cases. I agree completely with you on how many things can go wrong with them and how many it might take to make a good one. |
mepstein |
Sep 12 2019, 06:18 PM
Mark, Whatever you do, don't throw out the ones with rock dent in the stainless cover. That can be metal worked out and polished. Can be made nearly undetectable in most cases. I agree completely with you on how many things can go wrong with them and how many it might take to make a good one. (IMG:style_emoticons/default/biggrin.gif) Nothing is getting thrown out. Some I will redo. Some I will set aside to have redone by someone with more skill than myself. I would say to never use tools to remove the trim ring, only your fingers and never try to turn a mirror that is stuck. It needs to be lubed and then it will turn freely. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:44 AM |
