| mb911 |
Sep 20 2019, 07:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,857 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I have misplaced my plastic hoses that connect to the inlets of the m/c .. I have a 914 rubber quick connect m/c so the metal barbs are npt needed.. Any idea on what the plastic material is and can I just buy it locally?? Oh and proper size if that is possible.
| bdstone914 |
Sep 20 2019, 08:13 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,431 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have misplaced my plastic hoses that connect to the inlets of the m/c .. I have a 914 rubber quick connect m/c so the metal barbs are npt needed.. Any idea on what the plastic material is and can I just buy it locally?? Oh and proper size if that is possible. I think the line ID is 8mm. PMB is caring a flexible line. I gave some original lines that you could adapt. Bruce |
| mepstein |
Sep 20 2019, 08:23 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,021 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A little research - SAE J1401 complaint hose is the standard for resisting DOT3 or DOT4 fluid.
I looked on amazon -Tygon 2375 Clear Brake Fluid Reservoir Hose 5/16" 8mm ID 1 Foot I don't know what type of place would sell local. Maybe FLAPS. |
| bdstone914 |
Sep 20 2019, 09:05 PM
I think the lines are in the 15-18 inch lenght.
I would check Mcmaster-carr too. |
| bbrock |
Sep 20 2019, 10:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
If you wind up having to order, I'd probably just get the PMB lines. IIRC, they are pretty reasonably priced. They are a pain to bend but not have to put the barbs on will preserve a couple extra years of your life.
| 914werke |
Sep 20 2019, 11:22 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,801 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Ben i have some pre-owned ones if you want to go that direction
| mb911 |
Sep 23 2019, 04:21 PM
Ordered from PMB today.. Thanks everyone.
Lo-Fi Version | Time is now: 26th November 2026 - 06:24 PM |
