914 TD at the autocross.... |
PatrickB |
Oct 11 2019, 03:45 PM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Installed new Bilsteins and 150 lb Eibach springs on RSR adjustable mounts. After reading lots of threads here, tried disconnecting the back swaybar for the last event of the season. Not sure if it's the right move, still getting some body roll. Car has a front swaybar that's stock (I think). Pictures were taken by someone at the track that took pictures of most of the cars there. Thoughts on body roll? too much? Other cars that were faster had more roll...
BTW 350 treadwear tires are currently the limiting factor in how fast we get around the track. [attachmentid=715 338] Attached thumbnail(s) |
Justinp71 |
Oct 11 2019, 03:57 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
You can compare with this video if you want, I was the second fastest street car on new treadwear 100 tires... https://www.youtube.com/watch?v=6B56cF5qwPQ&t=27s
19mm front sway bar, stock front torsion bars, Bilstein shocks, 200lb rear springs (six). Alot of quickness in the autocross is being smooth and carrying as much speed as you can thru the turns. Honestly I wasn't all that fast there just wasn't a lot of tough competition that day. |
PatrickB |
Oct 11 2019, 04:18 PM
You can compare with this video if you want, I was the second fastest street car on new treadwear 100 tires... https://www.youtube.com/watch?v=6B56cF5qwPQ&t=27s 19mm front sway bar, stock front torsion bars, Bilstein shocks, 200lb rear springs (six). Alot of quickness in the autocross is being smooth and carrying as much speed as you can thru the turns. Honestly I wasn't all that fast there just wasn't a lot of tough competition that day. You have less body roll, car looks really good! Was considering slightly heavier springs in the back... |
Justinp71 |
Oct 11 2019, 04:24 PM
You can compare with this video if you want, I was the second fastest street car on new treadwear 100 tires... https://www.youtube.com/watch?v=6B56cF5qwPQ&t=27s 19mm front sway bar, stock front torsion bars, Bilstein shocks, 200lb rear springs (six). Alot of quickness in the autocross is being smooth and carrying as much speed as you can thru the turns. Honestly I wasn't all that fast there just wasn't a lot of tough competition that day. You have less body roll, car looks really good! Was considering slightly heavier springs in the back... Thanks. I have an aluminum case six (3.2) so I naturally have to have slightly heavier springs off the bat. Also I probably cranked up the front sway bar to mid notch. |
PatrickB |
Oct 11 2019, 04:38 PM
You can compare with this video if you want, I was the second fastest street car on new treadwear 100 tires... https://www.youtube.com/watch?v=6B56cF5qwPQ&t=27s 19mm front sway bar, stock front torsion bars, Bilstein shocks, 200lb rear springs (six). Alot of quickness in the autocross is being smooth and carrying as much speed as you can thru the turns. Honestly I wasn't all that fast there just wasn't a lot of tough competition that day. You have less body roll, car looks really good! Was considering slightly heavier springs in the back... Thanks. I have an aluminum case six (3.2) so I naturally have to have slightly heavier springs off the bat. Also I probably cranked up the front sway bar to mid notch. 1.9 AAZ diesel, not sure but I think it's a little heavier than stock. |
mlindner |
Oct 12 2019, 06:01 AM
Senior Member Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Justinp71, thanks for sharing the video. Very nice driving and your 914-6 GT looks really fast. Best, Mark
EdwardBlume |
Oct 12 2019, 06:59 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
For AX to eliminate body roll, go with larger torsion bars, 19MM front sway bar, and reconnect the rear bar.
That's what I did. YRMV - I also had a welded in roll bar with a forward arm. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:42 AM |
