For the water cooled folks.., Min diameter for lines going up front. |
Dr. Roger |
Jun 30 2005, 05:16 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
what would you use as a minimum diameter lines going up front.
I'm thinking I will use steel or copper. 30 bucks. Anyone know of the cheapest connection for Gates green stripe? Cost? Rog |
914GT |
Jun 30 2005, 05:30 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
3/4" pipe works fine. I wouldn't go smaller. Bigger is ok but not necessary.
Dr. Roger |
Jun 30 2005, 05:34 PM
can you think of any reason for not using steel elect. conduit? I will be using 25% coolant....
914GT |
Jun 30 2005, 06:00 PM
Conduit and copper pipe easier to work with, less crush resistance. But if you do a good job tucking the pipe into the indentations under the floorpan it will be protected quite well. I've noticed that galvanized fittings get a 'furry' looking corrosion in them which I have not seen with plain steel pipe. Copper or aluminum preferred over galvanized. If you want no worry of crushed lines go with black steel pipe. A pain in the butt to bend, but I jack the car up under my lines. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:05 PM |
