I'm gunna get ball busted on this Q:, SBC water inlets/outlets |
Dr. Roger |
Jun 30 2005, 06:36 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
The front of the engine has two water openings and there is a third at the intake manifold.
What goes where? My new electric water pump has three openings but.... ARGHHH..... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ewdysar |
Jun 30 2005, 06:48 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
The opening on your intake manifold is where the t-stat goes, it's where the warmed water leaves the engine. The 2 ports on the front of the block are where the cooled water goes into the engine. So plumb the top opening to the radiator, include a tank and cap before you leave the engine compartment if you want, on the way to the inlet of the radiator. Plumb the outlet hose coming back from the radiator to the inlet side of the pump and the outlet(s) to the front of the block.
At least that's my understanding... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) anyone else? Eric |
messix |
Jun 30 2005, 08:21 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
its a good idea to mount the purge tank to be the highest point in the cooling system. this allows you to get air out of the cooling system.
neo914-6 |
Jun 30 2005, 09:33 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Roger,
where's your balls? (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Hope this very technical drawing helps... Attached image(s) |
914GT |
Jun 30 2005, 10:08 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
You found an engine-mounted electric pump that will clear the firewall? |
Dr. Roger |
Jul 1 2005, 12:14 AM
Felix,
LOL... Whew, still got the nads..... Thanks so much for the diagram. Now I know why the water pump has one big opening and two smaller ones. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Guy, believe it or not, i'm going to use a front mounted pump without using it on the front of the engine. "Why" you ask???? I ordered the wrong type of pump and realize it would take just as much time to repack, send off, and have a new one shipped as it would take to adapt the one I have right now. Either that or I'm a glutton for punishment. Probably the latter....... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Eric and Troy, thanks for the valuable information. and not busting my balls... Unlike Felix...... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
messix |
Jul 1 2005, 01:16 AM
that diagram is usefull, but still use two points to fill the cooling system. one at the radiator and one at the engine [purge tank].
this will make bleeding all the air out of the system easy. |
neo914-6 |
Jul 1 2005, 02:33 AM
ya know this is not current information but basically accurate... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Get to work, July 24th is coming up soon! |
Dr. Roger |
Jul 1 2005, 03:07 AM
You guys are always so damn helpful. I wanna' not like U but I can't help but think y'all are OK.
July 24th????? What, where, who, why????? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Tomorrow bebe gets a preliminary electrical check up. Start the rad mounts... more? =-) |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:23 AM |
