Fuel, oil, brake lights. tachometer sockets, Which sockets go where? |
mnot |
Nov 1 2019, 03:02 PM
Newbie Group: Members Posts: 10 Joined: 1-November 19 From: Florida Member No.: 23,614 Region Association: None |
I have a set of gauges I am using for a project. The gauges did not come with all the sockets. I have some sockets that are Porsche and VW, but they do not seem to match to the insulated ones on the gauges I have. Anyone have some detailed info on which sockets go where and how they are grounded?
I know it's a little vague.. but.. thanks Mike |
ndfrigi |
Nov 1 2019, 03:14 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
mnot |
Nov 1 2019, 09:37 PM
This is what I have. I am not sure about the fuel level socket warning light on the lower right. It has a ground that is internal to the socket, phenolic. I thought one of the spade terminals was broken off, but it is recessed so a terminal could not be installed on it and the ground is down the side of the socket. Attached thumbnail(s) |
theer |
Nov 2 2019, 06:35 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Not sure I understand the question, and maybe this is obvious... but the sockets are for lights - either illumination or for warning, blinker, etc. The light bulb holders come in two varieties: plastic with two spades for power and ground, and metal with one spade for power where the metal body is the ground path to the gauge housing. The metal type requires that the gauge housing itself has a ground terminal.
mnot |
Nov 2 2019, 11:28 AM
Not sure I understand the question, and maybe this is obvious... but the sockets are for lights - either illumination or for warning, blinker, etc. The light bulb holders come in two varieties: plastic with two spades for power and ground, and metal with one spade for power where the metal body is the ground path to the gauge housing. The metal type requires that the gauge housing itself has a ground terminal. Which sockets get the two spade sockets and which ones get the single spade... and which one gets the single spade"plastic" with ground down the side of the socket? |
FlacaProductions |
Nov 2 2019, 12:14 PM
Senior Member Group: Members Posts: 1,628 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
This may/may not help....note the note that indicates the illustration is shown upside down - since that's the way you usually view these when you're working on them!
mnot |
Nov 2 2019, 02:54 PM
This may/may not help....note the note that indicates the illustration is shown upside down - since that's the way you usually view these when you're working on them! What type of socket would go in 7? Where would the plastic socket with one spade and the ground down the side go? Unfortunately I am starting with a bag of parts. thanks all |
FlacaProductions |
Nov 2 2019, 05:02 PM
mnot |
Nov 2 2019, 05:51 PM
Black plastic double connector is for #7/ Fuel reserve - see pic. (black + 2 red/white stripe - the lower one in the pic) I believe the black plastic sockets with one space and side ground are gauge lighting - #1's. There is only one black plastic socket with one spade and side ground in the bag. Are you sure all the dash lights get those? thanks |
FlacaProductions |
Nov 2 2019, 08:57 PM
i'm not - these are pics I took last week when I pulled my wheel and gauges to get them freshened up - and now i'm away from the car for a while....
mnot |
Nov 5 2019, 01:23 PM
I am still trying to find out which type of socket goes into each of the gauge holes. I have three types of sockets, plastic two prong, plastic one prong with a ground(?) tab on the side and the all metal single prong.
FlacaProductions |
Nov 5 2019, 01:33 PM
Are you sure you have the correct number of sockets?
barefoot |
Nov 5 2019, 01:54 PM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Here's another shot, hope this helps:
mnot |
Nov 6 2019, 04:10 PM
mnot |
Nov 6 2019, 04:11 PM
mnot |
Nov 6 2019, 07:43 PM
Could I assume that the metal sockets go into the gauge where there is a metal stub out and the plastic ones go where the gauge is nearly flush?
FlacaProductions |
Nov 6 2019, 09:42 PM
Here's another shot, hope this helps: That helps. But the fuel gauge, what socket is used hidden behind the dash pad. thanks Black wire and 2 red/white wires for fuel reserve light - that's a black plastic connector with two leads on it and a side ground. |
FlacaProductions |
Nov 6 2019, 09:52 PM
otherwise- it's just 3 single wires that plug directly onto the spades on the gauge. #4, 5 and 6
Lo-Fi Version | Time is now: 16th June 2024 - 04:02 PM |
