V8 Conversion - Water temp sending unit, To drive stock oil temp gauge |
DickSteinkamp |
Nov 23 2019, 09:48 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Which sending unit will give the most accurate reading when used with the stock oil temp gauge to use the gauge as a water temp gauge in a V8 conversion? It will need to be NP threads (hopefully 1/8"). It would be great if 190-200 F would be around mid scale on the gauge.
drifter914 |
Nov 23 2019, 12:48 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
If you have FI you may need a 3-pole sending unit ( one for the ECU).
ClayPerrine |
Nov 23 2019, 02:32 PM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I would suggest you make an adapter fitting to put the oil temp sender into the manifold fitting next to the thermostat on the small block. Or drill and tap if you have a blank boss on the manifold.
Liquid is Liquid, and using the stock 914 sender insures you have the correct sender for the gauge. |
DickSteinkamp |
Nov 23 2019, 05:29 PM
DickSteinkamp |
Nov 23 2019, 05:31 PM
I would suggest you make an adapter fitting to put the oil temp sender into the manifold fitting next to the thermostat on the small block. Or drill and tap if you have a blank boss on the manifold. Liquid is Liquid, and using the stock 914 sender insures you have the correct sender for the gauge. I have read/heard that oil in an air cooled Porsche/VW is substantially hotter than the water in a typical water cooled engie. If that is the case, the gauge which is centered at normal oil temp in an air cooled engine would not be centered at normal water temp in a water cooled engine. (BTW, my stock gauge is not marked with degrees) True? |
Chris914n6 |
Nov 23 2019, 08:35 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You're right. The oil temp gauge is going to read low. Middle on most water gauges is 212F and is 'numb' so as to not freak out drivers when it gets a little warm or cool.
There is a chance a different sender is in a better range. Probably easiest is using an early 944 gauge and sender which is standard 1/8npt. Also comes in white. (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.myonlinestore.eu-431-1574563042.1.jpg) |
DickSteinkamp |
Nov 24 2019, 09:28 AM
Probably easiest is using an early 944 gauge and sender which is standard 1/8npt. Also comes in white. Thanks, Chris. That would work if the gauge pod is the same size as the 914, and if the 914 fuel level sender would drive the 944 gauge properly. Any idea on those two qualifiers? It looks close enough to a 914 cluster to be stock. |
914forme |
Nov 24 2019, 10:04 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
the 924 - early 944 can be modified to be a quad gauge. It is the same size.
But if you wanted to the oil temp can be switched to a water temp gauge with a bit of modifying , and use the proper sender from the kit. Just pops out and you can add in the new one.You have to change out the insert pin, but not hard at all. I add a short piece of heat shrink around the post to avoid grounding issues. Over kill, yes, but I do it just the same. I'm a bit old school stuff like that. |
DickSteinkamp |
Nov 24 2019, 11:09 AM
the 924 - early 944 can be modified to be a quad gauge. It is the same size. But if you wanted to the oil temp can be switched to a water temp gauge with a bit of modifying , and use the proper sender from the kit. Just pops out and you can add in the new one.You have to change out the insert pin, but not hard at all. I add a short piece of heat shrink around the post to avoid grounding issues. Over kill, yes, but I do it just the same. I'm a bit old school stuff like that. Thanks. Do you mean replace only the 914 oil temp gauge with the 944 water temp gauge and not the whole combo gauge? I'm not sure what the "kit" is, but it looks like OE 944 senders are available new. |
914forme |
Nov 24 2019, 12:22 PM
Thanks. Do you mean replace only the 914 oil temp gauge with the 944 water temp gauge and not the whole combo gauge? I'm not sure what the "kit" is, but it looks like OE 944 senders are available new. That would work, good thought, LOL that could be 4 screws, the gauge face might be a bit short of the 914 window, never thought about trying that one. |
DickSteinkamp |
Nov 24 2019, 02:31 PM
That would work, good thought, LOL that could be 4 screws, the gauge face might be a bit short of the 914 window, never thought about trying that one. Well, I thought it was YOUR thought. Can you explain your idea further? I obviously missed it. (IMG:style_emoticons/default/sad.gif) |
Chris914n6 |
Jul 12 2020, 12:39 AM
Measured Ohms for the gauges. My 944 gauge is the 2nd style with the circuit board back and round connector, but that shouldn't matter. I believe the 924 gauge has the separate modules like the 914 if you wanted to swap just that part.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1594536780.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1594536781.2.jpg) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:20 AM |
