Wheel size that will fit under GT flares |
9144me2enjoy |
Nov 25 2019, 02:09 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
With Steel GT Flares (Auto Atlanta) installed on a 914 what are you limited to on wheel & tire sizes? Example 15x7s & 15x8s or 6x16s & 7x16s with standard 5 bolt conversion on a 1974 914. Thank you
914forme |
Nov 25 2019, 05:25 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Depends on the car
Fuchs - Factory Mym471 option used 15x7s all around and added a spacer in the back. Or was it 6s GT used 15x7 front and 15x8 or 15x9 in the back, 15x9 is a rare ish wheel all the ones I found where off RSRs or 911 STs. Sizes where all over the place. Period pictures will also show GT with Minilites on the rear in a 15x10 under factory rears. Modern 16 or 17s will be a bit wider, and spacers might be involved. Only real way to know is Mock up and measure, then order. If you use a CNC flat disc. Easy way is a piece of plywood, cut out to 17" or what ever your wheel diameter is. I would use a router for this with fixture that goes off the center. But can be done with a screw in the middle and a piece of string. One you have that, measure out 130mmm and that is your hub wheel stud center. Reality since it is radius cut all measurements in half so 65mm if doing radius. 8" if replicating a 16" wheel, 8.5" for 17, You can figure it all out with a square. That will get you your offset, and you max width, then search for a wheel to fit, and make it a smaller than you max. Tires come into play and require a bit of space themselves. They do make a device to do this never used it, sorry no help on that one. This has come up a lot in the past and a google search not even formatted correctly produced great results and lots of good reading here is what I typed in 914World GT flare Wheel width HTH |
Racer |
Nov 25 2019, 07:58 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Comes down to suspension - ride height, spring rates, shock stiffness, camber, alignment, tire size etc.
Most folks will fit a 7" front, 8" rear. 8" front and 9" rear will also fit, I've seen wider in the back, but really? Comes down a bit to application - racing? if so, is there a class limit? If street tire, sometimes the brand/size you want to run just doesn't exist. 225 front 245-275 rear is common. 15", 16" or 17" Some even stuff 18" wheels in there. |
9144me2enjoy |
Nov 25 2019, 08:12 AM
Thanks for the information. Happy Thanksgiving!
Lo-Fi Version | Time is now: 23rd May 2024 - 01:46 PM |
