| AndySomogyi |
Jan 19 2020, 01:23 PM
Newbie ![]() Group: Members Posts: 22 Joined: 29-January 19 From: Bloomington IN Member No.: 22,839 Region Association: Upper MidWest |
Hey All,
I'm swapping in a built N/A Subaru 2.5 (~210 hp), but I'd like to keep as stock, or at least period correct look and style as possible. So, I'd like to stay with an early 70's stamped metal air filter box. Really want a stamped metal box, I don't care for the look of the plastic boxes. I like the look of the 914 2.0 box, I think it would look really good there, and it's the exact style that I want. I suspect it's probably a bit small for a 200 hp motor though. So, I'm trying to find something with a similar style. Note, I'm modifying the intake manifold to have the throttle body in the top, just like the 914. I've thought about maybe a Datsun 280Z airbox (it's square, slightly bigger), or maybe a BMW 2002 air filter (round style, sits on top of the motor). There are lots of round style that I can easily adapt. But I don't know, I kind of like the look of the square one, that sits off to the side. So, the air boxes that I've looked at are:
| Mark Henry |
Jan 19 2020, 01:43 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Fab in a bigger snorkel and pipe to the TB. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif)
| AndySomogyi |
Jan 19 2020, 02:22 PM
Fab in a bigger snorkel and pipe to the TB. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) That's the approach I'm leaning towards. Bigger snorkel and TB tube is easy. I'm just not sure if the air filter itself is big enough, or it would cause too much intake restriction. But yeah, I like this airbox, think it looks the best, and they're pretty easy to find. |
| Chris914n6 |
Jan 19 2020, 02:53 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,564 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Filter size is fine. Inlet and outlet air holes will need to be bigger -- at least the size of the TB.
| Johny Blackstain |
Jan 19 2020, 02:57 PM
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region
Not to stir up any hornets but K&N makes a perfect fit, high flow filter for the box. Larger snorkel & tb seat should not affect the fit of the filter inside the box. And to satisfy the hornets, I'm sure someone else makes a perfect fit, high flow filter that fits. OEM Mann filter would likely be pretty restrictive.
Lo-Fi Version | Time is now: 28th October 2026 - 09:28 PM |
