| DucRS |
Jan 24 2020, 02:54 PM
Member ![]() ![]() Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California |
Hello guys
I just installed the new 914Rubber Brake Master Cylinder and once installed I found only ONE electrical connection on the Master but my 1973 2.0 has TWO wires that connect to the old Master. Both wires are brown except one has a white streak. What’s your advice? TIA! ![]() |
| lierofox |
Jan 24 2020, 03:01 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California
I believe for the single terminal switches, the wire to plug in is the "Brown with White stripe" wire.
| jcd914 |
Jan 24 2020, 03:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I believe for the single terminal switches, the wire to plug in is the "Brown with White stripe" wire. (IMG:style_emoticons/default/agree.gif) The other wire is a ground wire and the new switch with a single connector grounds through the switch body to the master cylinder body. A while back there was someone selling NOS brake warning switches in the classified section. Jim |
| Mark Henry |
Jan 24 2020, 03:05 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Didn't notice this on the 914 rubber MC I got for a spare, but mine also has one connection. Likely you can just ground the brown wire or if your original switch is good just swap them.
| lierofox |
Jan 24 2020, 03:11 PM
Didn't notice this on the 914 rubber MC I got for a spare, but mine also has one connection. Likely you can just ground the brown wire or if your original switch is good just swap them. I'd say tape it off and stow it. Shouldn't need the brown wire with the new switch, but, doesn't hurt to leave it there, just unplugged. |
| DucRS |
Jan 24 2020, 03:13 PM
OK, gonna connect the Brown/White stripe wire and disregard the solid Brown for now. I tossed the old Master so can’t use the old one.. SMH.
Thanks guys |
| DucRS |
Jan 24 2020, 03:17 PM
Oh, side note. This is the last of my “to do list” before I attempt to fire her up after 28 years... todayI will crank her over for the first time.
| Mark Henry |
Jan 24 2020, 03:26 PM
Oh, side note. This is the last of my “to do list” before I attempt to fire her up after 28 years... todayI will crank her over for the first time. (IMG:style_emoticons/default/cheer.gif) |
| Mikey914 |
Jan 24 2020, 03:41 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,775 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Thanks for responding guys,
Yes the only ones we could get without making new ones were the 2pole version. So no you don't need the ground side. Do bleed the brakes thoroughly, this may require a few attempts as this system is hard to get the bubbles out. |
| roblav1 |
Jan 24 2020, 06:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I just did this today and swapped out the switches. Old switch went in new MC.
| StarBear |
Jan 24 2020, 06:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Crossing fingers for your successful fire up. Long time.... (IMG:style_emoticons/default/aktion035.gif)
Lo-Fi Version | Time is now: 15th April 2026 - 01:23 AM |
