jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
Does anyone sell a head CC kit for our type 4 heads? I can only find the bug ones that go to 94 mm disc.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you have a CC syringe you can level your head and use water with a drop of Dawn soap (to break surface tension) and you can measure it good enough for stock.
I made most of mine with tape, compass, drill and a jigsaw, you want at least 1/8" clear plastic. They'll look at you funny but most pharmacy's will give you a syringe, you want the biggest they have. I've always used water with a drop of soap, because most oils, chemicals, etc., will wreck the rubber piston of the syringe plunger. I used to have a 50cc syringe, it was boss, but it wore out. Had a glass graduated burette, busted that shit. Just CCed a pair of heads with a 3cc syringe what a PITA, I need a new syringe. (IMG:style_emoticons/default/rolleyes.gif) |
jsaum |
If you have a CC syringe you can level your head and use water with a drop of Dawn soap (to break surface tension) and you can measure it good enough for stock. I made most of mine with tape, compass, drill and a jigsaw, you want at least 1/8" clear plastic. They'll look at you funny but most pharmacy's will give you a syringe, you want the biggest they have. I've always used water with a drop of soap, because most oils, chemicals, etc., will wreck the rubber piston of the syringe plunger. I used to have a 50cc syringe, it was boss, but it wore out. Had a glass graduated burette, busted that shit. Just CCed a pair of heads with a 3cc syringe what a PITA, I need a new syringe. (IMG:style_emoticons/default/rolleyes.gif) Ok I’ll look around for some plexiglass and try the home made method. I have a 60 cc syringe. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,351 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
James you need a disc for 96's?
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
Me too. 96mm. But won't a 94mm disc seal?
jsaum |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 961 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
I bought a cheap 100ml buret off Amazon for $20 for cc'ing heads that is surprisingly accurate (I weighed 100ml of water measured with the buret and it was 99.5g, suggesting that the buret only has .5% error).
https://www.amazon.com/gp/product/B00KI25CE...=UTF8&psc=1 |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,786 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I made mine pretty much like Mark did with this exception. Beside 3/16" hole for the syringe tip I drilled a smaller 1/8" hole as an air vent. Also, I use some axle grease around the perimeter to seal the plastic disc against the head. I used alcohol vs soapy water but that doesn't really matter. Feed Supply's are good places to buy a large syringe cheaply. (IMG:style_emoticons/default/beerchug.gif)
914werke |
The level is a good touch.
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,461 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
If you are doing this more than once (or even once) pipettes are the way to go. I plan on upgrading to a 100ml glass burette with stand. All are available on Amazon.
TargaToy |
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 713 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region ![]() ![]() |
Do any of you guys live near a Tractor Supply store? They sell syringes in big sizes. Learned that little tip when I was having trouble getting some motorcycle calipers to bleed right after a full rebuild.
You want a big cow syringe. (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Amazon has all the parts and stuff, if you dont have a place local. I used some food coloring because clear or light colored water was hard for me to see. Vent hole on opposite side is very helpful.
Lo-Fi Version | Time is now: 1st September 2025 - 12:24 AM |
