F.S. : MPS modules (4) for Porsche 914s, Removed from running 914s. |
914LIVE |
Mar 7 2020, 07:18 PM
Newbie Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None |
Superhawk996 |
Mar 8 2020, 10:42 AM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Pics of end caps requested. Has the adjustment screws been opened?
kkid |
Mar 8 2020, 10:45 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Do you have access to a vacuum gauge to see if the units hold vacuum adequately?
914LIVE |
Mar 8 2020, 01:10 PM
Will do the VACUMM TEST again and report back. One module is unmolested on the screw access. Three of the modules have the screw access point opened. ============================ |
Superhawk996 |
Mar 8 2020, 02:52 PM
914LIVE |
Mar 8 2020, 06:58 PM
Unmolested is the 027. ===================== |
914LIVE |
Mar 9 2020, 07:02 PM
MPS Update : Vacuum at 10 inHg vac. 1) # 027 holds at 15 minute test (no losses) 2) # 049 holds at 15 minute test (no losses) Other two units pending testing Thank you. ================================================== |
JeffBowlsby |
Mar 10 2020, 03:18 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 027 is not a 914 MPS, I think it may be for a 411/412
The pressure test is for 15 in/HG, and industry literature uses 18 inHG. If fit leaks, it should leak fairly quickly. 10 inHG is not sufficient. |
914LIVE |
Mar 10 2020, 11:58 PM
No problem. I will increase to 18. Update soon. ================================= |
914LIVE |
Mar 10 2020, 11:59 PM
027 used in two 1973 914s. ======================== |
914LIVE |
Mar 11 2020, 02:37 PM
Increased test to 18 inHg vac on both the 027 and the 049 and absolutely NO LOSSES. 30 minutes on both and NO LOSSES. Thank you. ================================= |
Lo-Fi Version | Time is now: 1st June 2024 - 01:56 AM |
