> Jacking point damage?
Biggles
post Mar 25 2020, 10:00 AM
Region Association: England
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
post Mar 25 2020, 10:15 AM
Resident German
They are crooked because those aren't jacking points!
There is noting solid on the other side, using them as jacking points means you are deforming your floorpan.
Biggles
post Mar 25 2020, 10:29 AM
QUOTE(SirAndy @ Mar 25 2020, 04:15 PM) *
Ok not good. Thanks. I had used a reference on the world referencing round 'donuts' that were safe to jack on - evidently not! What purpose do those areas serve ?
So where is good to Jack up the car?
dr914@autoatlanta.com
post Mar 25 2020, 10:37 AM
jack under the engine mounting bar, or the front cross member, these are to rest jack stands with pieces of plywood to cushion the jack stand from the donut
QUOTE(Biggles @ Mar 25 2020, 09:29 AM) *
bretth
post Mar 25 2020, 11:05 AM
I thought all four doughnuts were for jacking up/supporting the car. I always used a padded floor jack there and don't think i ever bent any except the rusty one under the hell hole on my car.
Biggles
post Mar 25 2020, 11:13 AM
Cheers George. No engine mounting bar. It's a 6. I've been jacking on the rear donuts or on the trailing arm pick up points at the rear - no good?
QUOTE(dr914@autoatlanta.com @ Mar 25 2020, 04:37 PM) *
post Mar 25 2020, 11:17 AM
Resident German
The donuts were used to suspend the cars on the assembly line.
Biggles
post Mar 25 2020, 11:18 AM
QUOTE(SirAndy @ Mar 25 2020, 05:17 PM) *
Wow. Thanks. Still learning.....
post Mar 25 2020, 11:19 AM
Resident German
And if you check the location of the donuts in the front and look at that location from above you'll find that it is only supported by the thin sheetmetal of the floor pan.
In the rear, it's only supported by the thin sheetmetal of the triangle piece in that corner.
There is nothing structural backing up any of the donuts ...
wes
post Mar 25 2020, 11:58 AM
wes
I saved this year’s back from here.Attached Image
kroelofsen
post Mar 25 2020, 02:12 PM
Region Association: Europe
QUOTE(SirAndy @ Mar 25 2020, 06:19 PM) *
Hi SirAndy, I'm sorry to say I don't agree with you for the rear donuts... Few weeks ago took of the triangle plate + donut to check for any rust and to make it straight again. The donut itself is directly under the frame member and supports it fully, see picture.
The front I don't know yet...
gandalf_025
post Mar 25 2020, 03:14 PM
You can see the point on the floor ,in front of
the engine mount where it has been dented in
from many years of being jacked up with a
floor jack with a piece of wood on it..
rgalla9146
post Mar 25 2020, 04:34 PM
QUOTE(gandalf_025 @ Mar 25 2020, 05:14 PM) *
(IMG:style_emoticons/default/agree.gif) Very common damage on 6s but hard to avoid as it is a very
solid point on the chassis and provides great height when jacked there.
ctc911ctc
post Mar 25 2020, 04:47 PM
SirAndy! MORE OF THESE FACTORY PICTURES PLEASE!
QUOTE(SirAndy @ Mar 25 2020, 11:17 AM) *
mbseto
post Mar 25 2020, 04:59 PM
So aside from accuracy, there's no reason to replace these?
bretth
post Mar 25 2020, 06:13 PM
I think if it was designed to hang the whole car on, it will stand up fine to a properly placed floor jack. I don't think i would use the rear firewall area for a jack though.
drem914
post Mar 25 2020, 06:49 PM
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack.
@cuddy_k ?
SO.O.C914er
post Mar 25 2020, 07:25 PM
I agree these are the jack points if they are not show something in writing from Porsche indicating the true jack points. I’ve used these since the 1980’s mine are not bent. I’m bent but they are not. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif)
bkrantz
post Mar 25 2020, 08:29 PM
QUOTE(SirAndy @ Mar 25 2020, 10:15 AM) *
There is on mine (with some custom backing plates inside the front floor).
914e
post Mar 25 2020, 09:32 PM
QUOTE(bkrantz @ Mar 25 2020, 07:29 PM) *
I thought about doing that as well. What gauge of sheet metal did you use?
- Lo-Fi Version Time is now: 22nd September 2026 - 08:46 AM
