Installed the LeMans Seat, comfy |
olav |
Jul 6 2005, 09:24 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
I just got a LeMans seat to replace my old funky seat. It's pretty comfy, it would be better if they removed some of the cushion though from the back and seat so I don't feel pushed forward or sitting high.
I guess I'm just used to the flatness of the orignal seat... (IMG:http://photos1.blogger.com/blogger/461/319/320/914_new_seat.jpg) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
smooth_eddy |
Jul 6 2005, 09:27 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
Does your head hit the targa top? If not are you taller than 6 foot? E
olav |
Jul 6 2005, 09:32 PM
I'm 6'3" and my head does not hit the targa top. I don't think I could wear a helmet though and have the targa top on. So I kept my olden seat for that in case I go on a track. |
GaroldShaffer |
Jul 6 2005, 09:49 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I love my LeMans seat. You sit a little higher but at 5'7" I can still wear my helmet with the targa top on, but it is close.
Attached image(s) |
tat2dphreak |
Jul 7 2005, 07:10 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
those are slick! whare do you get them?
GaroldShaffer |
Jul 7 2005, 08:14 AM
HERE (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
JohnM |
Jul 7 2005, 09:18 AM
914 enduro driver Group: Members Posts: 179 Joined: 23-July 04 From: San Diego Member No.: 2,387 |
I'm thinking about getting these, but I'm 6 foot and have the same worry about headroom with helmet on-- granted only on a few occasions a year. Anyone have a measurement of how much higher these make you sit? Perhaps sit in stock passenger seat (moveable slider seat) and measure head clearance then sit in Le Mans and measure same-- maybe even experiment with tilt/slider settings to measure max. clearance? Thanks, John
olav |
Jul 7 2005, 09:24 AM
If you get them from the dude at http://www.gts-classics.com/lemans.html (Stephan) he can modify the seats to remove some of the thickness from the padding from the seat cushion and the back. He recently did that for someone that used the seat in a 904 and wanted to use a helmet. |
GTeener |
Jul 7 2005, 09:46 AM
914 Girl Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
Looks nice (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Is the Rallye ST version the same except with holes for a 5/6 point harness? Does the seat cushion come out like the standard seat? |
GaroldShaffer |
Jul 7 2005, 09:50 AM
My Lemans seat has the hole in the cushion for the 5/6 point harness. No the seat bottom does not come out like a stock seat does. |
GTeener |
Jul 7 2005, 09:54 AM
But what about the lap belts? Do they have to go over the sides of the seat? |
GaroldShaffer |
Jul 7 2005, 10:01 AM
Yes they do. Fits real good. I haven't done any track stuff yet just AXing, but with this seat and 5 point belts your (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) stays put! I don't have my car here (its gone for a clutch tube repair) otherwise I could post a picture for you. |
GTS |
Jul 10 2005, 12:37 AM
Member Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
Hi All,
thank you for the comments on the seats. We tried to get the seats as low as possible but for those who like to race I could modify the seats with a removable seat cushion,make it a bit thinner and you still can sit on the duralastic belts. Yes the seat belts for the LeMans go over the sides but should have the right ergonomical fit. On the Rallye ST you have a bit wider seat with the side hole for the seatbelts and the lap belt hole,they fit nicely into the 914 but.... The rear padding doesn't fit or has to be modified...or a la GT and the tilt / slider bracket has to be modified as the mounting base is slightly 12 mm wider. But John has done it and as well another gentleman. If you emal me I can send you the pictures of the Rallye ST installed... I am too dumb to unload pictures in a reply..... They should also be posted under Seats for 914/6 GT here in the forum. regards Stefan GTS |
Lo-Fi Version | Time is now: 8th June 2024 - 01:37 PM |
