> Charcoal canister
mb911
post Apr 14 2020, 08:37 PM
I looking for fuel tank carbon canister that would be easy to hide.. Any thoughts or suggestions?
Steve
post Apr 14 2020, 10:40 PM
I have mine mounted in front of the battery where the CD box normally mounts. This way you only have to run one hose to the engine compartment. I am using one of the later plastic ones that is easy to refill.
mb911
post Apr 15 2020, 05:35 AM
QUOTE(Steve @ Apr 14 2020, 08:40 PM) *
Any pictures of your install @steve ?
Steve
post Apr 15 2020, 06:48 AM
QUOTE(mb911 @ Apr 15 2020, 04:35 AM) *
I can take some pictures later today. I ran the single hose down the passenger side rocker panel. Works great, no more gas fumes. 75/76 914’s had the canister in the engine compartment. They ran a really small hose down the tunnel with the fuel lines. The canister either mounted next to the battery or in front of the trunk.
Steve
post Apr 15 2020, 07:06 PM
QUOTE(Steve @ Apr 15 2020, 05:48 AM) *
Hard to see, but the late model plastic charcoal canister, fits perfectly between the battery and the firewall. I attached the bracket where the 914-6 CD mounts to, which is not needed with a 3.2
Steve
post Apr 15 2020, 07:13 PM
With the canister in the engine compartment, you only need one hose to the expansion chamber on the gas tank.
Steve
post Apr 15 2020, 07:17 PM
In the originality forum, you can see the stock locations in the engine compartment.
http://www.914world.com/bbs2/index.php?sho...amp;hl=canister
mb911
post Apr 16 2020, 04:54 AM
Thanks.. I have some thinking to do on this
jaredmcginness
post Apr 16 2020, 06:26 AM
Not to Hi jack.... but while on the topic.
If running a carb setup is there a proper way route the charcoal/PCV set up. Had a tough time searching for this topic.
Steve
post Apr 16 2020, 06:31 AM
QUOTE(jaredmcginness @ Apr 16 2020, 05:26 AM) *
Most carb air cleaners have a fitting for the canister. If they don’t make one.
mb911
post Apr 16 2020, 06:38 AM
To be clear I have Carbs with a GT filler neck. Just trying to make the garage not smell like gas.. Thats my goal anyway..
914Toy
post Apr 16 2020, 08:51 AM
I have a 911 engine with carbs. The filter return line is connected to the air cleaner - per the diagram Steve added above. No gas smell in the garage.
Steve
post Apr 16 2020, 10:33 AM
QUOTE(mb911 @ Apr 16 2020, 05:38 AM) *
Sounds like you might need an external expansion chamber. 911’s used an external expansion chamber, but they are kind of bulky.
Mark Henry
post Apr 16 2020, 12:34 PM
that's what I do!
QUOTE(Steve @ Apr 16 2020, 12:33 PM) *
(IMG:style_emoticons/default/agree.gif) You have to have an expansion chamber and a charcoal canister.
QUOTE(Steve @ Apr 16 2020, 08:31 AM) *
Weber rain hats you'll have to drill a hole on the top, add a grommet and a 90 degree fitting.
porschetub
post Apr 16 2020, 03:31 PM
QUOTE(mb911 @ Apr 17 2020, 12:38 AM) *
Ben I don't really think you can remove the engine bay smell due to the nature off carbs I noticed more smell when I used the twin K&N setup ,I'am now back to using the stock air cleaner and it seems less.
Any system will only be effective when you have suction and pressure when the engine is running ,perhaps I'am wrong but that's my take on it.
Steve
post Apr 16 2020, 05:19 PM
QUOTE(porschetub @ Apr 16 2020, 02:31 PM) *
You are correct, but there are also gas fumes that come from the gas tank vent. If this breather/vent is not connected to an evaporative system, you will also get gas fumes in the cabin and the garage. Even driving my car to the store, if the windows were rolled up, I still had gas fumes in the car. I have heard of people taking the tank breather and running it through a fuel filter and then out the bottom of the car. I tried all the tricks and my cabin still smelt like gas as well as the inside of the garage. After installing the expansion chamber and charcoal canister the fumes in the cabin and in the garage went away..
Mark Henry
post Apr 16 2020, 05:50 PM
that's what I do!
It's funny I've been too lazy to finish mounting my charcoal canister.
All I have is the expansion tank and the small plastic hose, plugged (IIRC) and I never smell gas.
gonzo54
post Apr 23 2020, 05:39 PM
Orange Crush
I bought a plastic charcoal canister that I can replenish to replace my 73 metal canister and I have a couple of questions:
1. What is the direction of flow on the plastic canister? Flow from the fan to the air cleaner towards the plastic removable cap?
2. How do you know if the charcoal pellets need to be replenished? I opened it up and the it was full of pellets that look normal.
Thanks-Rick
gonzo54
post Apr 23 2020, 05:43 PM
Orange Crush
This is the plastic canister I bought and hopefully I can use the existing mounting bracket on my 73.
-Rick
Steve
post Apr 23 2020, 06:18 PM
QUOTE(gonzo54 @ Apr 23 2020, 04:43 PM) *
-Rick
I doubt it... I thought the 73 had a metal container which is more flatter.
This plastic one is the one I have mounted between the battery and the firewall.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:59 AM
