Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
I have a desmogged '75 2.0. Apparently there is no PCV valve and the only crankcase vent I'm aware of is from oil filler neck area directly to air cleaner intake. Are there adverse affects with just running that hose to an overflow bottle instead of the air cleaner port? Can it just be vented or is vacuum beneficial?
Rand |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Ok, I know that BS filter thing isn't working yet. SOMEONE help an idiot here... |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
the barbed fitting on the oil breather IS the PCV valve.....that clearish whitish ring screws off so the PCV valve can be serviced....do it every oil change. The vac is beneficial and helps to allievate the crankcase from being pressurized....
Rand |
Huh? '75 2.0, no PCV valve. No clearish whitish ring. Just a tit to connect a hose to the air cleaner. This is a vent to alleviate crankcase pressure.
Question is: Does connecting the hose to the intake (thus picking up some vacuum) really make a difference over just venting it out to an overflow bottle? If so, WHY? |
Rand |
Thanks Britt for the reply! I appreciate it.
But I'm still wondering about the difference between simply venting to the outside (whether to an outlet, or an overflow bottle, or a filtered capture and restore system, or whatever) compares to venting to a vacuum via the intake and how that extra air flow makes a difference. ??? |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
there is no benifit to venting it to a puke can. there is a reason that it is vented to the air cleaner, YOU wont have to breath the fumes coming out of the crank case. its not going to hurt preformance or make the engine run any differently.
its good for the enviroment keep it vented to the intake. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Nah, run it to the air cleaner. No advantage to changing it.
bd1308 |
woah. sorry then.
Lo-Fi Version | Time is now: 13th July 2025 - 08:19 PM |
