Broken clutch cable, Inspection recently showed no fraying |
ctc911ctc |
Jun 20 2020, 01:13 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
‘74, 2.0
When we got her I inspected the entire car, replaced/rebuilt just about everything that was critical, my son loves the car, drives it all of the time and was on his way to his favorite fishing hole (ah to be 18 again) when he calls and says: the clutch cable broke! Looks like it broke in the middle! |
Superhawk996 |
Jun 20 2020, 01:33 PM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Check condition of body to transmission ground strap.
Needs to be a zero ohm connection When this ground strap is missing or high resistance, the clutch and throttle cables become the ground when starting. This crates a lot of heat in the cables and leads to the type of failure you have - sudden failure without warning. |
porschetub |
Jun 20 2020, 02:48 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Check condition of body to transmission ground strap. Needs to be a zero ohm connection When this ground strap is missing or high resistance, the clutch and throttle cables become the ground when starting. This crates a lot of heat in the cables and leads to the type of failure you have - sudden failure without warning. (IMG:style_emoticons/default/agree.gif) probably not high tensile after being heat cycled. |
jim_hoyland |
Jun 20 2020, 06:35 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Interesting ; where do you attach the multimeter probes ? Anywhere on the chassis
Mikey914 |
Jun 21 2020, 12:08 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I’ve been a victim of this. Mine started with the clutch cable stretching then snap.
fiacra |
Jun 21 2020, 08:21 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 344 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Interesting ; where do you attach the multimeter probes ? Anywhere on the chassis This was addressed in a recent thread, although with a slightly different flavor of this problem. Hope this helps. http://www.914world.com/bbs2/index.php?showtopic=346626 |
Lo-Fi Version | Time is now: 6th June 2024 - 06:10 AM |
