2056 spark plug gap, 40 Dell's, Jacobs energy box, Bosch blue coil, C30 cam,Bosch SVDA Dizzy |
914rat |
Jun 22 2020, 12:22 PM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
Trying to tune my 914 that has been asleep in my climate controlled garage for 10 years. runs good in the upper rpm range but shitty at lower range. What gap should I use on NGK BR6ES plugs? 40 Dell's, Jacobs energy box, Bosch blue coil, C30 cam,Bosch SVDA Dizzy?
VaccaRabite |
Jun 22 2020, 12:52 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Start with 914 stock gap. Thats what I am using with my 2056.
ZAch |
Rand |
Jun 22 2020, 12:55 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Which is....?
.7mm or .028 for a 2.0 But I seriously doubt spark plug gap is causing the symptoms. |
Mark Henry |
Jun 22 2020, 12:58 PM
Did you clean the carbs?
914rat |
Jun 22 2020, 01:17 PM
porschetub |
Jun 22 2020, 01:45 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Are you running vacuum off the carbs for the SVDA ?
914rat |
Jun 22 2020, 04:07 PM
nditiz1 |
Jun 22 2020, 05:03 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Could be the jets. Was it running great before and not now or never running smooth.
RPM range not to be confused with throttle pressure. At what RPM does it run smooth? If it is throttle pressure that would be more so jets. |
914rat |
Jun 22 2020, 06:06 PM
Could be the jets. Was it running great before and not now or never running smooth. RPM range not to be confused with throttle pressure. At what RPM does it run smooth? If it is throttle pressure that would be more so jets. From idle to 2200 it's a bit docile and rough and it loves throttle and rpm's over 2000. It's a 914 with carbs I think the plugs in it are fouled so I bought new 1's thus the gap question. I was going to change them tonight and test drive but we are having storms. I don't drive it in the rain. |
anderssj |
Jun 22 2020, 06:56 PM
Dog is my copilot... Group: Members Posts: 1,663 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
After you do the plugs, check the idle jets. Dell idle jets tend to get blocked. Even a partial block on one idle jet will cause problems, especially in the RPM range you mentioned (up to 2200 or so).
One other thing I notice with my car (also with Dells) is that when summer get here, it starts running a little rich and I need to lean the idle mix out just a little, about 1/4 turn "in" on each of the idle adjustment screws (#62 in the picture). You'll see if you're running rich when you pull the old plugs. (NOTE: 1/4 turn is approximate, once you're done be sure to check the color of the new plugs to make sure you don't end up too lean--YMMV, other standard disclaimers apply). Air density decreases as temperature and humidity increase, so warmer weather is just like gaining altitude and a carb'ed car will run richer. The effect is most noticeable at low RPM (e.g. like when pulling away from a full stop, especially if going up a hill). On my car, the engine even sounds a little different--boggy/lopey, and kind of fat, like when it's up in the mountains. Hope this helps! |
rhodyguy |
Jun 23 2020, 06:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
IIRC when using Jacob Ingnition items the spark gap is increased. Are you using Jacobs spark plug wires too? The back in the day jacob's ads made interesting claims.
Mark Henry |
Jun 23 2020, 08:16 AM
IIRC when using Jacob Ingnition items the spark gap is increased. Are you using Jacobs spark plug wires too? The back in the day jacob's ads made interesting claims. Yep, IMHO BS claims, like it could "sense" a combustion chamber flame out and could re-ignite the burn. Like other CDI's it delivers several pluses per firing to achieve this. It's a CDI not much different than stock /6, MSD, crane, permatune etc. I don't know if you can increase the gap with a blue coil, I know you can with a high power coil made for a CDI. |
rhodyguy |
Jun 23 2020, 10:19 AM
'Cures all jetting problems'. Back when HotVws and dune buggies was still being published. Full page adds.
Mark Henry |
Jun 23 2020, 12:06 PM
914rat |
Jun 24 2020, 04:43 PM
I am a 914 sucker I mean guy.
914rat |
Jun 24 2020, 04:51 PM
Plugs in gapped at 28. Helped some but the blast of Sea Foam in the drivers front venturi and the subsequent 6 in flame comimg out the rear venturi smoothed it out about 90%. I added Seafoam to the gas as a stabilizer. I will go around and check all the intake and exhaust for leaks. Maybe check the idle jets and take on a short 10 min ride.
Thanks for all the input it was both entertaining and helpful. |
914rat |
Jun 24 2020, 04:53 PM
As for the Jacobs energy box. Should I keep it in the car or should I hook it up to my bug zapper ?
porschetub |
Jun 24 2020, 06:20 PM
What is your fuel pressure ? because you have fouled plugs I can only assume you have fuel bowl overspill,take one air cleaner off and see if the carb throat is wet when idling.
Did you clean out the pump nozzles ? and check float bowl heights ? the nozzles block very easily and cause raw fuel to drip out instead of a fine atomized spray or if totally blocked not work @ all and equal backfires. Rebuilding carbs is a difficult job to do right,everything has to be spot on...period. Don't forget to make sure your ignition system is 100%,NEVER try to tune carbs unless you have checked plug leads for example,if they look old replace them as they are cheap enough same applies to the rest of the system. Have you checked the timing ?,good luck. |
914rat |
Jun 25 2020, 04:43 PM
What is your fuel pressure ? because you have fouled plugs I can only assume you have fuel bowl overspill,take one air cleaner off and see if the carb throat is wet when idling. Did you clean out the pump nozzles ? and check float bowl heights ? the nozzles block very easily and cause raw fuel to drip out instead of a fine atomized spray or if totally blocked not work @ all and equal backfires. Rebuilding carbs is a difficult job to do right,everything has to be spot on...period. Don't forget to make sure your ignition system is 100%,NEVER try to tune carbs unless you have checked plug leads for example,if they look old replace them as they are cheap enough same applies to the rest of the system. Have you checked the timing ?,good luck. I have a fuel pressure regulator and a guage. The pressure is fine and it is in time. I ran the car out of gas and suspect some trash got by the fuel filter or got left behind when the carbs were cleaned. I am going to drive the car and work on all these things to get that last little bit of tune resolved. It is very close now. Thanks for the input. |
type2man |
Jun 25 2020, 08:58 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Turn it on and pull one plug wire at a time to see if one of the plug wires does NOT change the idle speed, then check that idle jet. Or just remove all the idle jets and clean them. Sometimes you clean them and they get more crud after a short drive so check them twice if need be.
Lo-Fi Version | Time is now: 6th June 2024 - 05:00 PM |
