WTB: Mounting plate for MPS |
BillC |
Jun 28 2020, 07:04 PM
Senior Member Group: Members Posts: 547 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Found one. Thanks! |
JOEPROPER |
Jun 29 2020, 06:16 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? |
JeffBowlsby |
Jun 29 2020, 08:19 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have the mounting plate for you. Will PM. Looks like the above poster has the grommets. Screws are easy to come by.
BillC |
Jun 29 2020, 08:20 AM
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? |
JOEPROPER |
Jun 29 2020, 08:37 AM
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. |
BillC |
Jun 29 2020, 10:12 AM
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. @ JOEPROPER PM sent. Thank you very much! |
G e o r g e |
Jul 2 2020, 01:14 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
Lo-Fi Version | Time is now: 8th June 2024 - 06:02 PM |
