Engine dies then kicks in!, Midway thru a spirited driving day! |
Ian Stott |
Jul 12 2020, 06:42 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
So I am in the switchback section of the Cabot Trail with 3 other vehicles and the teener is performing well, coming out of a really nice 180 degree turn I get on on the throttle aggressively and engine dies, then catches again. This happened a few times more, but I carried on. Made it home, but it was happening more often. All thoughts and suggestions appreciated.
Ian Stott Moncton Canada |
Bartlett 914 |
Jul 12 2020, 08:40 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
So I am in the switchback section of the Cabot Trail with 3 other vehicles and the teener is performing well, coming out of a really nice 180 degree turn I get on on the throttle aggressively and engine dies, then catches again. This happened a few times more, but I carried on. Made it home, but it was happening more often. All thoughts and suggestions appreciated. Ian Stott Moncton Canada My first thought is an electrical issue. Swap around the relays on the relay board. Rotate all fuses to make sure there is good contact. I recently went through similar problems. In my case, I also had backfiring then all would be good. I am using "Hot Spark" in place of points. I found the sensor and the magnet were rubbing. I would also lookt your distributor points or what you are using in place of them |
windforfun |
Jul 12 2020, 09:10 AM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Maybe a TPS issue of some kind?
iankarr |
Jul 12 2020, 09:21 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I’m gonna say fuel. The “dies when I step on it after twisties” says dirty filter sock in the tank or filter to me. The lower the fuel level (from sloshing or using) the more it’s likely to happen since there’s less force pushing gas through the obstructions to the pump.
Jamie |
Jul 12 2020, 12:22 PM
Senior Member Group: Members Posts: 1,035 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I’m gonna say fuel. The “dies when I step on it after twisties” says dirty filter sock in the tank or filter to me. The lower the fuel level (from sloshing or using) the more it’s likely to happen since there’s less force pushing gas through the obstructions to the pump. When I pulled the tank for repairs I mangled the new "sock" and decided it wasn't worth the trouble. I placed a filter between tank outlet and front mounted pump, believing the filter was more accessible for replacement. Also means the tank can be removed without complete draining by simply pinching off the outlet hose. |
ericoneal |
Jul 12 2020, 12:27 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
This happened to me once and it was a loose coil wire.
GaroldShaffer |
Jul 12 2020, 12:56 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
This happened to me once and it was a loose coil wire. (IMG:style_emoticons/default/agree.gif) Same thing happen to me. |
saigon71 |
Jul 12 2020, 01:50 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
FI or carbs?
BillC |
Jul 12 2020, 02:49 PM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Could be low fuel level in the tank. Have you looked inside the tank? Fuel level senders do go bad occasionally.
Ian Stott |
Jul 13 2020, 08:25 AM
Thanks to all that chimed in, will check the sock in the fuel tank, I like the idea of adding an easily accessible in line filter, thanks for that tip.
Will double check for wires not making good contact, I did do that when I pulled over to check just that, everything seemed well connected. I replaced all relays this spring with the new ones from 914 rubber. I replaced the fuse panel a few years ago, with the more modern one that takes the bayonet style fuses and have been in there replacing the fuse for the wipers, evrything looked good in there as well. Doubt the fuel pump is the issue, my understanding it either works or it does not, will also check my fuel pressure, I believe I have it set at 28. Might be a good time to install a fuel pressure gauge! I believe we can run up to 35 psi without harming anything but wonder if it is necessary to go that high. Thanks to all who chimed in! Ian Stott Moncton Canada |
mrholland2 |
Jul 14 2020, 03:40 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
When I had one, it was the heavy key ring moving the ignition switch just enough to go off then on then off then on . . as the keys swung.
Lo-Fi Version | Time is now: 7th June 2024 - 06:53 PM |
