'70 vrs '71 wiring differences, Headlight switch, circuits and wiring |
IronHillRestorations |
Jul 15 2020, 04:53 AM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm doing a chassis harness replacement on a '71 4 cyl car. Not exactly sure what happened but there was some melted wires to the headlight motors.
I found a good salvage harness, and in the process of doing the swap. I've found a discrepancy between the wiring for the headlight switch. The replacement harness does not have a gray wire that was in the original harness, and did not include the switch. The gray wire in the original harness goes to terminal #56 on the headlight switch and to terminal "K" for the headlight motors. Doing more tracing today, but part of the problem is melted wires. The factory manuals do not show a wiring schematic for all years, so I can't compare the two. Anyone know the differences? I know there are different harnesses for each year model, except '76. I think the headlight switch is the same for '70 and '71 Any thoughts on this? @JeffBowlsby @ClayPerrine @raynekat @Spoke @BDStone914 |
JeffBowlsby |
Jul 15 2020, 07:58 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
71 was a transition year for the chassis harness, there are early and late 1971 versions. Is your replacement harness identical to the original harness? The tell tale is the steering column connector. Early is 12 pin, late is 14 pin.
Jul 15 2020, 08:37 AM
The car build date is 1/71. It’s got a 12 pin at the column
JeffBowlsby |
Jul 15 2020, 09:07 AM
Here is the switch circuitry diagram, if it helps:
https://bowlsby.net/914/WiringHarnesses/DashSwitches.pdf |
Lo-Fi Version | Time is now: 7th June 2024 - 10:18 PM |
