'71 Turn signal switch, Suitable replacement?? |
IronHillRestorations |
Jul 16 2020, 06:30 AM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm wading through some electric problems on a '71 that is getting a replacement chassis harness. This is a car with the 12 pin connector for the column.
The turn signal switch wiring has been hacked on a bit, and looking at replacing it, but I don't see a direct replacement. Anyone know what part will work, or can be made to work? |
914Sixer |
Jul 16 2020, 06:38 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
71 Beetle will work. All seven wires are loose. Have to make it into harness to plug in.
Attached image(s) |
Jul 16 2020, 06:46 AM
Thanks Mark! The next issue I'll have is trying to figure out how it's supposed to go. Not sure it was put together right, and there's no color wiring diagram for the '71
nditiz1 |
Jul 16 2020, 07:15 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I purchased this one a few weeks back, but am not sure if it will work with the 71. It works fine in my 74.
Amazon Turn Signal |
dr914@autoatlanta.com |
Jul 16 2020, 08:36 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jul 16 2020, 12:19 PM
yup only problem is that it is a real hassle to replace!! 71 Beetle will work. All seven wires are loose. Have to make it into harness to plug in. After closer inspection, it looks to be the only part of the harness that didn't let any smoke out, so I'm going to leave it |
duane-9146 |
Oct 31 2020, 02:20 PM
Vegas Duane Group: Members Posts: 4 Joined: 6-June 04 From: Las Vegas Member No.: 2,161 Region Association: Southwest Region |
71 Beetle will work. All seven wires are loose. Have to make it into harness to plug in. I'm trying to use this part to replace stock switch on my 70 914. What is the proper wiring color codes to connect to the 12 pin connector. Wiring instructions only lists 5 of the 8 wires coming from the switch. |
Oct 31 2020, 03:19 PM
lay the new one out next to the old one and follow the wire progression coming off of the switch
Lo-Fi Version | Time is now: 7th June 2024 - 05:22 PM |
