brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
the part number on one of these, is on the opposite side than the other two
I imagine one is early... the other style late ? - which is which? ? - do tail shift/SS clutch forks interchange? thanks in advance everyone brant Attached thumbnail(s) ![]() ![]() |
Morrie |
Member ![]() ![]() Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region ![]() ![]() |
I KNOW I am going to regret this, but here goes. What is the difference I am supposed to be seeing. Also, as far as I know, tail and side shift use the same fork..... as the difference is in the shifter... not the clutch....
Apologies if I missed the point. :-) the part number on one of these, is on the opposite side than the other two I imagine one is early... the other style late ? - which is which? ? - do tail shift/SS clutch forks interchange? thanks in advance everyone brant |
brant |
I think the Tail and side forks interchange also
and they certainly seem to be the same dimensions when held together the difference in the pictures the pair of forks have the part number cast on back side of the pivot bushing hole... the single fork has the part number cast on the same side of the pivot bushing hole. one style is likely early the other style likely late I just don't know which style is which |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
There is no operating difference.
The only anomaly of that period is the '70-'71 911 which was the first 'pull' type clutch. |
Lo-Fi Version | Time is now: 14th June 2024 - 01:51 AM |
