Replacing clutch.. my first time.. |
snflupigus |
Jul 11 2005, 08:58 PM
Member Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None |
Need to order the??? Clutch Flywheel -------????????????????? Throw-Out Bearing Flywheel Pilot Bearing Felt Washer for Pilot Bearing Throw Out Bearing Guide Clip Throw Out Arm Bushing Throw Out Arm Retainer Flywheel Seal/Rear Main Seal Flywheel O-Ring Flywheel Crush Washer Flywheel Bolt Clutch Alignment Tool Muffler Gasket CV Joint Gasket ??? Tell me, what do I really need and what is Pelicans suggestion for items that I might not need. I am hoping I can have my flywheel resurfaced. I'll know soon enough but I am unfortunately doubting it so I might buy a new one from pelican anyway. How terrible would it be to just replace the clutch and pressureplate only - hoping that the flywheel is ok. INSIGHT for a clutch replacement virgin NEEDED.... Thanks. |
ThinAir |
Jul 11 2005, 09:43 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
It's been awhile since I did one, but from my memory the essentials are the disk, pressure plate and throwout bearing stuff. When I just didn't have the money I was able to get by without doing anything to my flywheel, but it looked like it was in good shape.
I don't think you need to do the crankshaft seal unless you are having a leak issue, but it' probably one of those "while you are in there" kind of things. Once you pull off the flywheel you've done 99% of the work and the seal isn't that much money. If you change the flywheel or have it cut then I would think you'd need the rest of the flywheel stuff, except the bolt. You can't reassemble without a clutch alignment tool - an old input shaft is the best thing if you can find one. Don't forget the muffler bearing - most critical part in the whole job! YMMV. If I've screwed this up then I'm sure other's will jump on this and remind me of how stupid I can sometimes be! |
ArtechnikA |
Jul 12 2005, 04:47 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
many will replace the mainshaft seal "As Long As" you're in there...
RON S. |
Jul 12 2005, 04:56 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
It's not really a hard job,
With all the right tools layed out before you start,you can have the transmission out and on the floor in less than an hour.You have no need to remove the engine.Just have it blocked up securely.A 901 weighs about 75lbs,so no problem man-handling it or using a jack there. The rest is just replacing anything that can wear,or leak. Ron |
bd1308 |
Jul 12 2005, 06:11 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I did it.....
so you can do it too. |
grasshopper |
Jul 12 2005, 06:41 AM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
tat2dphreak |
Jul 12 2005, 07:09 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
it's not hard... get your flywheel turned at a machine shop if it's still in spec, that will cost much less than a new one...
I highly recommend the Pelican 15(ish) piece kit... it's good to replace all of those little things while you are already in there... |
snflupigus |
Jul 12 2005, 10:03 PM
btt
Lo-Fi Version | Time is now: 15th June 2024 - 12:50 PM |
