1970 Porsche 914 2.0, 1970 Porsche 914 2.0 |
melissakay |
Jul 12 2005, 08:11 AM
Newbie Group: Members Posts: 4 Joined: 12-July 05 From: Upstate South Carolina Member No.: 4,405 |
I have a 1970 Porsche 914 with a 1974 fresh rebuilt 2.0 liter engine and new clutch but a ruined transmission. Does anyone out there have any interest in purchasing this vehicle? Or does anyone out there have any interest in giving advice on getting an affordable transmission?
tat2dphreak |
Jul 12 2005, 08:14 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
welcome.
used trannys that still work can be had for around 150-200 in the classifieds... what makes you think the tranny is gone though? is the clutcsh adjusted? the linkage bushings in good shape? shifter adjusted? the tranny can usually be fixed... |
Bleyseng |
Jul 12 2005, 08:19 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
ArtechnikA |
Jul 12 2005, 08:33 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
welcome!
90% of the "no drive in any gear, makes a rattle noise" are ijn fact broken CV joints. if them's your symptoms, you may be back on the road for as little as a replacement halfshaft (but if one has failed, its partner may not be far behind...) so what - exactly - is it that makes you think the transmission is dead. it *can* happen, although the 914 transmission is normally quite reliable when driven by any 2,0 (4 or 6) engine. running them out of oil will eventually kill them tho... |
melissakay |
Jul 12 2005, 09:11 AM
I am getting used to this posting system and may be repeating myself but here goes...
bought a 1970 1.8 with a 1974 2.0 parts car......took both to a shop and had the engines switched out, also had a new clutch installed......after $5000 of work (ahhhh) i drove it home and the 1st, 3rd and 5th and reverse went out. took it to a shop in town and the guy took the tranny out and said there had been no fluid in it and it was ruined. Now I'm stuck with a 914 2.0 that I can't drive and don't know what to do about. |
dlo914 |
Jul 12 2005, 09:15 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
guys in south carolina hook up this lady w/ an affordable tranny please! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
RON S. |
Jul 12 2005, 11:04 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Rear shift,or side shift????
Ron |
Bleyseng |
Jul 12 2005, 12:29 PM
shit I'll put in a good used tranny for $2500 for ya!
damn, put in a good used one as they go for $200-300. The mechanic must have done something wrong when he installed the new clutch like not add tranny oil or effed up the pilot shaft seals or needle bearings..... |
Red-Beard |
Jul 12 2005, 01:03 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
#1. A short drive without oil will not kill the tranny. Not good for it but will not kill it.
#2. The symptoms are not of a dead tranny, but a poorly adjusted external shift linkage to gear selector. We do need to know if the tranny is side shift or tail shift. I have an unknown side shift in the garage which I could do a check up on - Rear cover pull and gear stack removal and check, ($350 plus shipping) or go through it and make sure it is a fully operational one that will last for several years with a complete new set of seals ($1000+ shipping). If you have a tailshift unit, you will need to aquire the other conversion parts. Not difficult and not too expensive. And, the sideshift is far far superior to the tailshift. Before I would go any farther, I would have someone who knows something about 901 or VW trannies take a look at it and do the shift rod alignment and fill it with oil. That will only cost you a few bucks and maybe a change of oil. If the mechanic is not familiar with how to adjust the shift linkage, connect to my homepage and print out the shift adjustment aritcles (One is for tailshift and one is for sideshift). I just re-read your post and my key belief is that the adjustment screw on the linkage was not tightened enough and now the shifter is not able to move backwards enough to enage gears 1-3-5. Other possible easy fixes: Roll Pin broken inside tail cover (tailshift) or in shift console (sideshift). If sideshift, broken cone screw also possible. Again, running without oil will not cause the symptoms you describe. James |
tat2dphreak |
Jul 12 2005, 01:10 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
listen to this guy! Red-Beard knows his shit about these trannies. I was hoping you'd see this thread... |
Jeroen |
Jul 12 2005, 02:17 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
dunno, but it sounds like you've been ripped off by the shop
hopefully a local member can check your car to see what's really wrong with your transmission or maybe someone local can point you to a shop that knows wtf they're doing sounds more like a mis alligned shifter mechanism... |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:16 AM |
