Removing radio |
Removing radio |
#1RAGE |
Jul 12 2005, 02:42 PM
Member Group: Members Posts: 139 Joined: 7-May 03 From: Saskatoon, SK, Canada Member No.: 664 |
I want to replace the aftermarket Blaupunkt cassette/AM/FM unit that that is in my car with a new CD player unit. I'm having trouble figure out how to remove the old radio. Maybe I'm just blind and not seeing something. Never done this before so maybe I'm just lacking the experience. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
I already removed the lower part of the dash that has the adjustable air vents on it... and that didn't really open up any options for me. A little help would be great. Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Mueller |
Jul 12 2005, 02:49 PM
got a picture? is the used unit a DIN style or does it have the 2 knobs like the old stereos? got a picture?? |
#1RAGE |
Jul 12 2005, 02:56 PM
Ya here ya go.
Attached image(s) |
#1RAGE |
Jul 12 2005, 02:57 PM
And the under dash.
Attached image(s) |
goose2 |
Jul 12 2005, 03:00 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Just like mine! I think you just pull the knobe off and unscrew the nuts underneath them...voila
tat2dphreak |
Jul 12 2005, 03:01 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) all 2-knobbers have a little nut under the knobs... and there looks to be an attachment at the back too... there SHOULD be anyway... that one is HARD to get to though... |
Mueller |
Jul 12 2005, 03:02 PM
ditto..... it looks like that black sheetmetal piece might have a screw thru it as well to support if from behind. |
McMark |
Jul 12 2005, 03:04 PM
Pull the knobs straight towards you until they come off, there are nuts behind them that hold the stereo in place.
The new style stereos will fit in the opening in the dash. You may have to use a metal file in the corners a bit to make it fit. If you want the dash material to look original, you have to make a plate like this out of sheet metal and use double sided foam tape to stick it to the dash. You can get basket weave material from an upholstery shop or I can get you some. Here's a picture of one I did. The shiny metal is custom piece you'd have to make. Attached image(s) |
#1RAGE |
Jul 12 2005, 03:45 PM
Thanks everyone! I got it! (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
Now I need to pick up a cd player and install it. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:21 PM |
