oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
I have a stock, other than Fireball ignition, 76 2.0 for 20 years. Runs flawlessly. Recently when first started, as I back out of the garage, I get a few random mild backfire-like pops from the engine. As soon as I put the car in 1st and drive away, it never does it again. I have not had the valves adjusted for the last 10,000 miles and they make no noise, so I haven’t bothered. Could this initial backfiring be a sign that the valves finally need adjusting?
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
Djet ..... Gremlins. But it still runs 50 years later
So dont mess with it. But they dont make noise so haven't bothered? Thats asking for it ! |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Go adjust your valves then if it still backfires it's likely too rich or too lean.
oakdalecurtis |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Go adjust your valves then if it still backfires it's likely too rich or too lean. (IMG:style_emoticons/default/agree.gif) 10k is too long besides. |
oakdalecurtis |
Go adjust your valves then if it still backfires it's likely too rich or too lean. [/quote] How can you tell if the mixture is too rich or too lean? |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
I was told, rich backfires from exhaust, lean up through the intake.
rjames |
[quote name='oakdalecurtis' date='Sep 10 2020, 12:18 AM' post='2849916']
Go adjust your valves then if it still backfires it's likely too rich or too lean. [/quote] How can you tell if the mixture is too rich or too lean? [/quote] To get it exactly right, you need a wideband O2 sensor to read what your AFR is at part load and WOT. Lots of options out there, but this is what I used PLX AFR |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
I have a stock, other than Fireball ignition, 76 2.0 for 20 years. Runs flawlessly. Recently when first started, as I back out of the garage, I get a few random mild backfire-like pops from the engine. As soon as I put the car in 1st and drive away, it never does it again. I have not had the valves adjusted for the last 10,000 miles and they make no noise, so I haven’t bothered. Could this initial backfiring be a sign that the valves finally need adjusting? Good for you for keeping a 76 stock. Don't know if some of the other posts are "braintrust worthy" As you probably already know the 76 is a little bit different animal than the others. A good 76 completely stock is worth more than most other 914-4's due to the low production numbers if that is your thing. Like a couple of others have posted,check you valve lash first....10k is a bit over time for not adjusting and is probably the likely cause. The next thing I'd check is a vaccum or slight exhaust leak. Don't know what distributor you are running but if a dual diaphram stock type on the dizzy I'd check those for leaks first. Post some pics if you can....very rarely do I see a good running stock 76, |
mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
I have a stock, other than Fireball ignition, 76 2.0 for 20 years. Runs flawlessly. Recently when first started, as I back out of the garage, I get a few random mild backfire-like pops from the engine. As soon as I put the car in 1st and drive away, it never does it again. I have not had the valves adjusted for the last 10,000 miles and they make no noise, so I haven’t bothered. Could this initial backfiring be a sign that the valves finally need adjusting? Valves are noisy if too loose. They can also become too tight, which is very problematic. |
oakdalecurtis |
Just got my teener back from a valve job. Mechanic said a few of the valves were “tight”, which he defined as opening a little too much. No more backfire on startup! (IMG:style_emoticons/default/piratenanner.gif)
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Great. Thanks for the follow-up to let us know what you did and that the issue was resolved. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 09:18 AM |
