QUOTE(oakdalecurtis @ Sep 9 2020, 04:54 PM)
I have a stock, other than Fireball ignition, 76 2.0 for 20 years. Runs flawlessly. Recently when first started, as I back out of the garage, I get a few random mild backfire-like pops from the engine. As soon as I put the car in 1st and drive away, it never does it again. I have not had the valves adjusted for the last 10,000 miles and they make no noise, so I haven’t bothered. Could this initial backfiring be a sign that the valves finally need adjusting?
Good for you for keeping a 76 stock.
Don't know if some of the other posts are "braintrust worthy"
As you probably already know the 76 is a little bit different animal than the others. A good 76 completely stock is worth more than most other 914-4's due to the low production numbers if that is your thing.
Like a couple of others have posted,check you valve lash first....10k is a bit over time for not adjusting and is probably the likely cause.
The next thing I'd check is a vaccum or slight exhaust leak.
Don't know what distributor you are running but if a dual diaphram stock type on the dizzy I'd check those for leaks first.
Post some pics if you can....very rarely do I see a good running stock 76,
