AAR Elbow?, AAR Elbow |
simonjb |
Sep 26 2020, 10:20 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
My hose to connect to the AAR to the CSV crimps because the angle is too tight. Yes, I could buy a longer piece, but I am wondering if there is an elbow part that looks like what Jeff is showing in his diagram, circled in Yellow...near the AAR
dangrouche |
Sep 26 2020, 11:17 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I have the 2.0 and do not use any elbow fitting. more chances for a vacuum leak.
Bleyseng |
Sep 26 2020, 11:38 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes there is but I think I bought them from a VW bus parts supplier, so look online there
rhodyguy |
Sep 26 2020, 11:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
'Stacked Elbow'. I think 914rubber is offering them. You need the 2 small pieces of connecting pipe too. Some of the other knockoffs offered are crap. When chasing vac leaks usually the last place looked.
Mikey914 |
Sep 26 2020, 12:35 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We make them and provide with metal
https://914rubber.com/branch-piece-air-dist...with-fittings-1 Attached thumbnail(s) |
rhodyguy |
Sep 26 2020, 12:41 PM
That's a pretty good deal.
JamesM |
Sep 26 2020, 12:49 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
JeffBowlsby |
Sep 26 2020, 01:03 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We make them and provide with metal I think he is looking for the other one, just the regular (13mm??) elbow 022.129.637 ^^^ (IMG:style_emoticons/default/agree.gif) a 90 degree elbow. |
simonjb |
Sep 26 2020, 01:58 PM
Mikey914 |
Sep 26 2020, 02:15 PM
Sorry, yes we have those too I say stacked elbow, and posted the wrong one. Have the hoses and metal connectors if needed for all
https://914rubber.com/split-y-aar-valve-1 Attached thumbnail(s) |
dlee6204 |
Sep 26 2020, 06:47 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
We make them and provide with metal I think he is looking for the other one, just the regular (13mm??) elbow 022.129.637 Yes, correct. Thanks !! It’s available from several sources as it’s also used on VWs. The metal sleeves are not as easy to find. |
porsche914rick |
Sep 26 2020, 06:54 PM
Member Group: Members Posts: 66 Joined: 6-August 14 From: Seymour, TN Member No.: 17,744 Region Association: South East States |
Frankvw |
Sep 27 2020, 03:37 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
you can find them on type4 VW T2B as well and they are sort of similair:
022 129 637 (for type4 injection) - 8$ 021 129 639 (for Type4 carbs) - 6$ 021 129 637C (different sizes on each end) - 5$ Maybe that is an alternative in case you are not succesful to find one. |
theer |
Sep 27 2020, 09:39 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I have an original one... it’s Yours for the cost of shipping.
EDIT: just realized this not the one you are looking for. |
bludden |
Oct 23 2020, 07:16 PM
Member Group: Members Posts: 57 Joined: 15-June 20 From: Charlotte NC Member No.: 24,380 Region Association: South East States |
This thread is helpful, as I need a new one of these, as mine is cracked. But it has a screw in the small opening, is this normal?
Mikey914 |
Oct 24 2020, 09:41 AM
Normal maybe. Factory correct no. The diagram at the top of the page shows the correct routing less the extra star in red.
If you look closely it should go to the decel valve. There is usually some creative plumbing to "fix" a problem. Are you running a stock FI setup? |
bludden |
Oct 24 2020, 11:05 AM
Normal maybe. Factory correct no. The diagram at the top of the page shows the correct routing less the extra star in red. If you look closely it should go to the decel valve. There is usually some creative plumbing to "fix" a problem. Are you running a stock FI setup? As far as I know I am. I ordered the part this morning so when I get it I will see if I can get it back to the original configuration, or if it acts odd, I'll know that there was some reason to do this. Thank you for your input! |
JeffBowlsby |
Oct 25 2020, 06:31 PM
The vacuum hose diagram above is correct, as verified by Brad Anders. Many years ago there was a previous diagram (based on someone else’s diagram) where two of the decel valve hoses were interchanged and incorrect. Brad A researched the function of the decel valve (see his webpage) and I issued the corrected diagram above.
Lo-Fi Version | Time is now: 10th June 2024 - 06:15 AM |
