Combo Gauge Temp Scale Numbering?, 914 641 101 50 |
FlacaProductions |
Sep 30 2020, 09:05 AM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have a small-red-scale combo temp gauge 914 641 101 50 - I've modified a couple of things including adding an LED indicator in the previously dead space and LED lighting.
Wondering about numbering the temp scale. Someone check my math - according to https://bowlsby.net/914/Classic/zTN_Elect_OilTempGauge2.jpg - this confirms the calibration markings on mine: 30 on the bottom line, 156.7 at the bottom of the red scale and 170 at the mid point of the red. So - extrapolating from that: 30c and 170c at the top That's a 140c swing - so that puts it 100c in the center with 65c at the 1/4 mark and 135 at the 3/4 mark - right? Converting to F: +/- 85 on the bottom, 150f at 1/4, 210 at 1/2, 275 at 3/4 and 335 at the top - right? Like this: This is assuming 200c sender and jives with the Bowlsby.net info. I reached out to https://www.heiler-tachodesign.de and they responded with the mock-up - but I was just sort of throwing numbers out there - but I think I'm close with this? Suggestions? Should I leave the bottom "85" off as it's basically meaningless or should I leave it for symmetry? Or....am I way off here?! |
Cairo94507 |
Sep 30 2020, 09:16 AM
Michael Group: Members Posts: 9,821 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Symmetry is what I think would look best. Or rescale the the numbers completely. (IMG:style_emoticons/default/beerchug.gif)
sbsix |
Sep 30 2020, 12:31 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 452 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
North Hollywood Speedometer has a replacement for the original 914-6 oil temp gauge. I had my gauges redone by them years ago. You can take a look at the corresponding temperatures on my gauge for a comparison. I did have to replace my oil sender at the front of the engine to complete the swap.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 08:12 PM |
