> Weber 44 IDF insulators, Gasket size
simonjb
post Oct 4 2020, 03:19 PM
KiwiMan
Hi,
So I am installing a set of insulator gaskets to reduce the heat to the carbs and cut back on fuel boiling after a drive. I ordered the kit from partsklassic. Seemed good until I went to instal the gaskets that go either side of the 44 Insulator. The gaskets are smaller than the insulator - 41 - see pics below. I've sent them an email. But in the meantime I've looked for 44 size and most places have a gasket for 40/44 IDF which implies they use the same gasket for 40 or 44. Can this be correct?
Attached Image Attached ImageAttached ImageAttached Image
rhodyguy
post Oct 4 2020, 04:05 PM
If the stud holes work, trim to fit. Not uncommon. How do they fit, Venturi wise, the carb bottoms and intake manifold tops? Sized correctly?
porschetub
post Oct 4 2020, 04:26 PM
They look more like 911 intake gaskets ?,sorry to ask but why don't you use the FI ones that are in every T4 gasket set ? you may need to port match the crappy manifolds around now but not a big deal it took me 30mins per manifold with a die grinder and that included getting rid of casting flashes and a quick tidy up.
Attached Image.
Good luck,cheers.
simonjb
post Oct 4 2020, 05:33 PM
KiwiMan
These fit between the Manifold and the carbs....Cutting these is a PITA, so I found some weber 44's online...Thanks
rhodyguy
post Oct 4 2020, 07:10 PM
Something like this in between the carbs and the intakes. Stock FI phenolic ones under the intakes.
- Lo-Fi Version Time is now: 17th November 2026 - 05:48 PM
