> Horrible scraping noise from rear left., Sounds like tire rubbing tire echoing in wheel well
Highland
post Oct 8 2020, 09:53 AM
I was once again test driving my car and while cruising along at 30~40 mph I heard a loud non continuous scraping noise; almost like a tire rubbing against a curb. I stopped to inspect and saw nothing. Everything was clean. No rub marks.
I pushed down on the suspension a few times and that seemed to help so I could limp home, but the noise started to get worse as I drove more. Probably drove a mile to get home.
Looking for some guidance cause a have no idea.
bdstone914
post Oct 8 2020, 10:12 AM
bdstone914
@Highland
Take the wheel off and inspect more closely.
Look for rub marks on tire. Could be a wheel bearing, shot trailing arm bushings. With weight off the wheel see if you have top to bottom play and/or side to side.
KSCarrera
post Oct 8 2020, 10:20 AM
Region Association: England
Worst case scenario: suspension mounting console broken away from chassis leg (hell-hole rust?). Broken spring?
VaccaRabite
post Oct 8 2020, 10:22 AM
En Garde!
I once had a noise like that and it ended up being a stone caught between the dust cover and the brake rotor. The noise it made sounded like my wheel was going to come off.
Pull the wheel for sure and give everything a solid look.
Zach
post Oct 8 2020, 10:35 AM
(IMG:style_emoticons/default/agree.gif) I'd check that brake shield first. (IMG:style_emoticons/default/beerchug.gif)
pt_700
post Oct 8 2020, 11:15 AM
get that wheel in the air and spin.
when the rear wheel bearing on my car went many years ago, i coulda described the noise like that.
ndfrigi
post Oct 8 2020, 11:29 AM
yes could be just the brake shield. It happened to me in SoCal WCR Palm Spring.
Hope just minor issue.
- Lo-Fi Version Time is now: 18th September 2025 - 05:03 PM
