Trigger points cleaning, What methods workd best for you? |
redshift |
Jul 14 2005, 05:28 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Today I need to get my trigger points cleaned up, and do some idle adjustments.
How do you best clean the trigger points? I was just going to yank the whole head off the dizzy, and bring her inside, where the heat works, 'cause Gawd, it's cold out there. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) M |
ArtechnikA |
Jul 14 2005, 05:54 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
well, what i did was place the trigger points assembly in a large container, such as a trash can. then i left them there, and put in the good, new set... i donno - burnish the contact points with something like a typewriter eraser (do they even still make those?) and hit 'em with a shot of contact cleaner. a small touch of Bosch grease on the rubbing blocks and call it good... i don't recall pulling the dizzy, but there was probably some interesting language extracting the trigger points assembly. that was only 15 years ago, i donno why i can't recall it better... |
redshift |
Jul 14 2005, 05:57 AM
Only got about 15k on these, I felt like I could be happy for another tuneup cycle before throwing another set in.
Tanks buddy. M |
bd1308 |
Jul 14 2005, 06:29 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
miles, i used carb cleaner to get the grease off.....and put some bosch grease (yellow ear wax looking stuff) on the cam and re-installed.
if you need one i have several good ones i could send you. |
redshift |
Jul 14 2005, 06:30 AM
Thanks Britt, I'll let you know about that.
I may well use earwax. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
bd1308 |
Jul 14 2005, 06:34 AM
works for me. hold your nose. took about a month's worth to work. and i collected the rest of the families too.
URY914 |
Jul 14 2005, 06:45 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Don't pull the dizzy to do it. That's more work that pulling the points out of the side of the dizzy.
But it is best to roll the car on the driver's side so you can just sit on a chair and work instead of bending over the back of the car. That is tip #75 on my list of things to do to make working on these cars easier. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Paul (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
redshift |
Jul 14 2005, 06:56 AM
LMAO!
You can work on your car with it sitting in your lap. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Dave_Darling |
Jul 14 2005, 09:14 AM
In my car, you can't get a screwdriver onto the two retaining screws for the trigger points when the distributor is still in the car. Let alone get room for the trigger points to slide out of the dizzy. --DD |
bd1308 |
Jul 14 2005, 09:23 AM
same here....roll the car to make the rotor point toward the index mark....take the dizzy out and pull the trigger points...
goose2 |
Jul 14 2005, 10:04 AM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
If you just remove the 12-13 mm nut that holds the dist. bracket to the block (don't loosen the 10 mm clamp nut), you can pull the dist with the bracket (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) without having to retime it when you put it back in.
bd1308 |
Jul 14 2005, 10:06 AM
yeah. I saw that in the Raby DVD. Damn that was a neat trick.
URY914 |
Jul 14 2005, 10:48 AM
OK, I stand corrected. You DO have to pull the dizzy out.
Sorry for the confusion. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) It's been awhile since my car has trigger points. (or anything else) Paul |
Lo-Fi Version | Time is now: 8th June 2024 - 12:11 PM |
