looking for door latch parts, pass door latch |
bernbomb914 |
Oct 18 2020, 08:15 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
opens from inside but not outside plus need a good type 4 engine or a good local eng mech
bdstone914 |
Oct 18 2020, 08:34 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Al Meredith |
Oct 19 2020, 11:22 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have a 1.7L 914 rebuilt engine on my engine stand that I want to sell. I want to sell it without cooling tin and front cooling shroud. The reason is that I use the rough condition tin and shroud on the test (run up) stand on all the engines I build. It comes with a flywheel ( proper end clearance ) and a stock cam so it can be used with FI. It is running on my stand now with a 32/36 carb and a distributor . I'm looking for $1000 as a long block . This would be a great engine to use while you are building your big motor . Al
Jett |
Oct 19 2020, 01:34 PM
Senior Member Group: Members Posts: 1,640 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I have a strong 2.0, recent head work, but block is 1.7.
bernbomb914 |
Oct 19 2020, 04:38 PM
Thanks for the response but I need somethink closer to so cal.
rasam |
Oct 20 2020, 01:55 PM
Newbie Group: Members Posts: 23 Joined: 10-March 15 From: Santa Fe Springs ca Member No.: 18,508 Region Association: Southern California |
PM sent
Lo-Fi Version | Time is now: 28th May 2024 - 11:53 PM |
