alternator bench test, alternator bench test |
goobstine |
Oct 28 2020, 11:39 AM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
can someone tell me where to hook my leads to bench test my alternator please ??
914Sixer |
Oct 28 2020, 03:59 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free.
bbrock |
Oct 28 2020, 05:01 PM
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free. Make sure they can test an alternator with external voltage regulator. I called my FLAPS, asked them specifically this question. "Yep, we can test it." Drove a half hour down from the mountains into town. NOPE, their machine said it could only be tested in the car. Waste of time. The factory manual has bench testing procedures for components (diodes, windings, etc.). |
goobstine |
Oct 28 2020, 09:49 PM
goobstine |
Oct 28 2020, 09:53 PM
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free. Make sure they can test an alternator with external voltage regulator. I called my FLAPS, asked them specifically this question. "Yep, we can test it." Drove a half hour down from the mountains into town. NOPE, their machine said it could only be tested in the car. Waste of time. The factory manual has bench testing procedures for components (diodes, windings, etc.). thank you, there is a way to do this with a volt meter and a dummy light i just dont want to charge the wrong wire. youtube has about half the info i needed it just wasnt specific enough for our type of terminals |
porschetub |
Oct 28 2020, 10:27 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free. That defeats the purpose. I am a student, trying to learn. thank you. Sorry to say but this forum will help you so take advise as given ,the way to bench test an altenator is beyond most skilled guys on here without the right gear let alone a guy learning ,its not a simple test. Lots of stuff on the net and lot is BS tread carefully. Good luck. |
MartyYeoman |
Oct 29 2020, 01:40 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Give Dean a call. He's an expert at these kinds of things.
www.deansautoelectrical.com |
76-914 |
Oct 29 2020, 02:39 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free. That defeats the purpose. I am a student, trying to learn. thank you. I can certainly support that attitude. I like to find out for myself whether I’m up to task or not. You wouldn’t believe the things I’ve accomplished when others have told me leave it to the pros. I think Spoke posted something here about testing out alternators once. @Spoke |
Spoke |
Oct 30 2020, 06:29 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
In the diagram below, the main components of the alternator are shown. There's 9 diodes, 3 stator windings, and an armature. Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately.
If you want to do a bench test, then you have to set up a fixture to spin the alternator while checking voltages and the current capability of the alternator. The diagram below can be used to do a bench test. Here's what you need to do to do a bench test: 1) Connect a battery between B+ on the alternator and the alternator case. 2) Do not install the voltage regulator. 3) Use the original wire harness to the voltage regulator connected to the alternator. 4) Short D+ and DF to put the alternator into maximum charge state. 5) Connect a GEN bulb as shown in the diagram. 6) Spin up the alternator to about 3k to 5k RPM; you should measure 16V at D+/DF to ground and B+ to ground. 7) The voltages between D+/DF and B+ should be within one volt of each other. This will give a good indication of alternator health. Attached thumbnail(s) |
bbrock |
Oct 30 2020, 08:32 AM
Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately. Assume you mean with the unit assembled. The factory manual DOES have bench testing procedures for individual components using an alternator tester but you have to have the unit opened up to do it. Thanks for that diagram! I could have used that when I rebuilt mine. |
goobstine |
Oct 31 2020, 02:56 AM
In the diagram below, the main components of the alternator are shown. There's 9 diodes, 3 stator windings, and an armature. Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately. If you want to do a bench test, then you have to set up a fixture to spin the alternator while checking voltages and the current capability of the alternator. The diagram below can be used to do a bench test. Here's what you need to do to do a bench test: 1) Connect a battery between B+ on the alternator and the alternator case. 2) Do not install the voltage regulator. 3) Use the original wire harness to the voltage regulator connected to the alternator. 4) Short D+ and DF to put the alternator into maximum charge state. 5) Connect a GEN bulb as shown in the diagram. 6) Spin up the alternator to about 3k to 5k RPM; you should measure 16V at D+/DF to ground and B+ to ground. 7) The voltages between D+/DF and B+ should be within one volt of each other. This will give a good indication of alternator health. Understood ! Now that's what i am talking about ! Thank you !!! |
goobstine |
Oct 31 2020, 09:54 PM
Make it quick and easy, take it to the local auto parts store. They have all the right test equipment, usually free. Make sure they can test an alternator with external voltage regulator. I called my FLAPS, asked them specifically this question. "Yep, we can test it." Drove a half hour down from the mountains into town. NOPE, their machine said it could only be tested in the car. Waste of time. The factory manual has bench testing procedures for components (diodes, windings, etc.). Yes , I have not had success with the alternator shops as well. My part came back tested good. 72 amp . I put it in my engine while i was building. It worked ! for a few minutes. I am not the best at electrical I mostly manage with a test light. My method has to change on this !!! I usually test them in the car and pull the ground or positive. generators i have always spun out of car with an impact wrench and volt meter. I had about half the information i needed from you tube and some more from a friend who was ratteling it off the left side of brain after i asked. Information is the key to everything. thank you |
goobstine |
Oct 31 2020, 10:01 PM
Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately. Assume you mean with the unit assembled. The factory manual DOES have bench testing procedures for individual components using an alternator tester but you have to have the unit opened up to do it. Thanks for that diagram! I could have used that when I rebuilt mine. thank you |
goobstine |
Oct 31 2020, 11:14 PM
In the diagram below, the main components of the alternator are shown. There's 9 diodes, 3 stator windings, and an armature. Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately. If you want to do a bench test, then you have to set up a fixture to spin the alternator while checking voltages and the current capability of the alternator. The diagram below can be used to do a bench test. Here's what you need to do to do a bench test: 1) Connect a battery between B+ on the alternator and the alternator case. 2) Do not install the voltage regulator. 3) Use the original wire harness to the voltage regulator connected to the alternator. 4) Short D+ and DF to put the alternator into maximum charge state. 5) Connect a GEN bulb as shown in the diagram. 6) Spin up the alternator to about 3k to 5k RPM; you should measure 16V at D+/DF to ground and B+ to ground. 7) The voltages between D+/DF and B+ should be within one volt of each other. This will give a good indication of alternator health. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:14 AM |
