Fuel Lines, Reinstalling the Fuel Tank |
ballsyfacts914 |
Oct 31 2020, 02:47 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All,
My fuel pump was vibrating which I could hear while driving. After some research, seemed like the issue was related to my fuel tank. Sure enough, after I pulled the tank, I found the screen to be pretty gummed up. Decided I should replace the fuel lines in the front so I ordered a kit from Auto Atlanta. My problem is that I got cocky and thought I had all the lines figured out but now I am not sure what goes where. Any straightforward videos or diagrams for reconnecting the fuel lines in a 1975. My main concern are the lines connecting to the expansion portion of the tank. Thank you |
Mikey914 |
Oct 31 2020, 06:38 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check with AA I’m sure they can tell you where the parts go. There are different sized inlet and outlet sizes on pump as well as filter.
bdstone914 |
Oct 31 2020, 07:13 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@ballsyfacts914
Any straightforward videos or diagrams for reconnecting the fuel lines in a 1975. My main concern are the lines connecting to the expansion portion of the tank. Thank you [/quote] There is only one 4mm line from the expansion tank to the rubber gromett that goes into the tunnel with the delivery and return lines. The big hose off of the tank goes in back of the tank and dumps extra fuel on the ground. The line with the screen in the delivery line. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:26 PM |
