ballsyfacts914
Oct 31 2020, 02:47 PM
Hi All,
My fuel pump was vibrating which I could hear while driving. After some research, seemed like the issue was related to my fuel tank. Sure enough, after I pulled the tank, I found the screen to be pretty gummed up.
Decided I should replace the fuel lines in the front so I ordered a kit from Auto Atlanta. My problem is that I got cocky and thought I had all the lines figured out but now I am not sure what goes where.
Any straightforward videos or diagrams for reconnecting the fuel lines in a 1975. My main concern are the lines connecting to the expansion portion of the tank.
Thank you
Mikey914
Oct 31 2020, 06:38 PM
Check with AA I’m sure they can tell you where the parts go. There are different sized inlet and outlet sizes on pump as well as filter.
bdstone914
Oct 31 2020, 07:13 PM
@ballsyfacts914 Any straightforward videos or diagrams for reconnecting the fuel lines in a 1975. My main concern are the lines connecting to the expansion portion of the tank.
Thank you
[/quote]
There is only one 4mm line from the expansion tank to the rubber gromett that goes into the tunnel with the delivery and return lines. The big hose off of the tank goes in back of the tank and dumps extra fuel on the ground. The line with the screen in the delivery line.
