Are You Using LED Headlight Bulbs?, Here Is What I Found |
914Sixer |
Oct 31 2020, 05:14 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
This is meant to be general information. I had to change out a turn signal bulb on my truck this afternoon. I got the housing out and was suprised to find the metal housings of the fans all corroded up on the LED bulbs. They have only been in there about 6-9 months. Bases are open to the air, so nowhere to trap moisture. This is dry West Texas, not sure what to think.
Attached image(s) |
Spoke |
Oct 31 2020, 06:12 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It looks like the fan shroud has reacted to the LED heat sink. The heat sink looks to be copper and the metal of the shroud or its coating is reacting with the copper. The copper looks good and as long as the fan is operating as it should, the LED should be ok. I would check with the manufacturer/supplier about this issue.
73-914 |
Oct 31 2020, 09:54 PM
Senior Member Group: Members Posts: 578 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
This is meant to be general information. I had to change out a turn signal bulb on my truck this afternoon. I got the housing out and was suprised to find the metal housings of the fans all corroded up on the LED bulbs. They have only been in there about 6-9 months. Bases are open to the air, so nowhere to trap moisture. This is dry West Texas, not sure what to think. Where was it made? |
914Sixer |
Nov 1 2020, 06:12 AM
Made in China.
Lo-Fi Version | Time is now: 3rd June 2024 - 07:09 AM |
