| jhadler |
Jul 15 2005, 10:58 AM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Hi all,
I'm looking for a bolt-in roll bar that I can use for Time Trials, but be able to remove for autox. I understand that Autpower makes one for the 914. Does anyone have any experience with them? I'd be looking at a roll bar that mounts to the rocker sills and to the B-pillar seat belt anchors. With an additional diagonal brace for GCR legality (so I can wear my harness at TT events). Pros? Cons? Good? Bad? Ugly?.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Thanks! -Josh2 |
| theol00 |
Jul 15 2005, 11:06 AM
Member ![]() ![]() Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
Autopower fits good is reasonabley priced and easy to install - fortunately I have not experienced how well they are in case of a roll over (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
| jhadler |
Jul 15 2005, 11:11 AM
I'd say that's fortunate! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
How easy would you say installation and removal would be? I understand that the sill plates need to be welded in, do they interfere with anything? E-Brake? Seats? Doors? -Josh2 |
| Jacques |
Jul 15 2005, 12:13 PM
Technician ![]() ![]() Group: Members Posts: 149 Joined: 20-April 05 From: Los Angeles Member No.: 3,954 Region Association: Southern California |
Recently purchased my 2nd Autopower. They call it the "Race Roll Bar" ..
Slit the carpet or remove, cannot be bolted in because of the hollow space underneath Also does not interfere with e-brake, doors, seats You will notice better handling almost immediately! (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Autopower in my '74 (IMG:http://ae.tc/STF/JPDVC00174.jpg) |
| MJHanna |
Jul 15 2005, 12:22 PM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
The front brace drops in the middle of the passenger floor board. Totally worthless
We made a longer brace to tie it in to the structure. When you bolt it in to the sails it really makes a difference. It’s not fun nor would it be easily to bolt in and out. Attached image(s)
| larryp |
Jul 15 2005, 12:31 PM
Member ![]() ![]() Group: Members Posts: 311 Joined: 9-May 03 From: Greenwich CT Member No.: 675 |
That's great. Do you have photos of how it fits around the firewall? And how/where it attaches to the longs?
| MJHanna |
Jul 15 2005, 12:53 PM
No I don't most of the shots I have are looking forward. I just dont have any looking that way. You have to take the Pad off the firewall. also it interfered with the e brake. I never cared as this was a track car. Attached image(s)
| Jacques |
Jul 15 2005, 01:01 PM
(IMG:http://ae.tc/STF/JACQ/rally.gif) The first one I got (3+ years ago) had this removeable brace which went through the passenger compartment. They did not offer this "passenger bar" when I rec'd my new one; which I picked up last week. |
| MJHanna |
Jul 15 2005, 01:10 PM
mine was older so your info is more current. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s)
| MJHanna |
Jul 15 2005, 01:11 PM
other side I looked and just dont have any interior shots, sorry (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
| mihai914 |
Jul 15 2005, 02:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
Maybe this will help.
| Jeroen |
Jul 15 2005, 03:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
I'd go for a Safety Devices rollbar...
Also, why remove it when you go ax-ing? |
| larryp |
Jul 15 2005, 03:38 PM
That does help, a bit. I am interested in seeing how it interferes with the ebrake, and if that can be worked around.
Jeroen - why is your preference for Safety Devices? And do they make one without a Petty Bar, since I need a passenger seat too. |
| John |
Jul 15 2005, 03:55 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Our Safety Devices cage (18+ years old) has no Petty bar (the diagonal from the drivers head down to the passenger door sill).
I don't know if the current one is any different. I have always liked ours, but it is fully welded in and has been added on to over the years. The top still comes off and there were no issues with the e-brake (when the car still had one). I would definately buy another or build one that is similar. I would, however change the front hoops and make them follow the windshield frame (without dashboard or any trim) more closely as it looks kinda funny now that the dash is gone and there is no trim inside the car. For a stock car, the Safety Devices worked very well and it did have the ability to be bolted in. There is no interference with the passenger seat or passenger area. There were 4 plates that welded to the tops of the longitudionals that had tapped bolts to bolt the cage in. Those could easily be hidden under the carpeting if the cage was to be removed. Just my opinion.... |
| larryp |
Jul 15 2005, 04:05 PM
I was looking at the safety devices site and saw cages. I think that is what you have too, if you are speaking of the windshield. I did not notice any roll bars, but will ask them.
| mihai914 |
Jul 15 2005, 05:43 PM
The model that was pictured does not interfere in any way with the handbrake, it mounts on top of the longs. I bought mine used so I don't know how old the model is, I do have a petty bar and as others have probably said, the quality seems very good.
| guywan914 |
Jul 15 2005, 07:20 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
I have installed a Safety devives roll cage in my car [ sorry Chris I bought it before I knew you]. the plates weld in and you bolt the cage to the plates. Can be removed or installed in 5-10 minutes. The only thing I didn't like about it was the placement of the windshield bar. I am going to relocate mine. AA has apiece on this cage on their 914 rebuild project [ forget the exact name]
| SirAndy |
Jul 15 2005, 07:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you could always go with a full roll cage from TC designfab. why must it be removeable?
http://www.tcdesignfab.com/ (IMG:http://www.tcdesignfab.com/andy11.jpg) (IMG:http://www.tcdesignfab.com/andy7.jpg) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) Andy |
| TravisNeff |
Jul 15 2005, 08:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
So how do you bolt the "bolt in" cages in? Don't laugh. I see that the feet of the cage just has bolt holes. So do you have to cut open the long so you can get nuts underneath? Or weld in a scab plate with nuts welded to the backside (and of course large enough holes in the longs for the nuts to pass through for a flush fit).
| mihai914 |
Jul 15 2005, 08:22 PM
I think that if you purchase them new they come with the plates that you weld to the body.
I have the longs open so I decided to make the mounting inside, I wouldn't recommend opening the long if you don't have to of course. |
Lo-Fi Version | Time is now: 15th April 2026 - 07:59 PM |
