8 Pages V  1 2 3 > »
> 2.0 or more, Bigger is better
930cabman
post Nov 14 2020, 05:07 PM
I cut my wrenching teeth on VW bugs and Type 3's back in the '70's and '80's. Been somewhat out of the game for several years looking to rejoin into the 914 world. Generally the easiest way for more kick is to increase displacement. Short of going to turbo's what is available as far as big bore kits. I am not interested in going the 6 cylinder route or chevy small block route. The car will be street only, but I need speed.
Tdskip
post Nov 14 2020, 05:38 PM
Welcome to the forum.
This is a well covered topic and search is your friend here. One easy thing to do is to Google “big bore engine 2256 914world.com” but drop the quotes when you paste that into Google.
Getting above 2.0L and having it last requires thought, effort and money. I’d start with what your goals are and how much actual budget you have, that will open or close doors.
Nogoodwithusernames
post Nov 14 2020, 08:41 PM
Head over to shoptalkforum and dig into the type4um lots of good big builds there. like 2.7-3.0 liters from Raby and some other more plausible builds too.
930cabman
post Nov 15 2020, 03:01 PM
QUOTE(Tdskip @ Nov 14 2020, 06:38 PM) *
Speed costs $$, how fast do you want to go. Universal statement
Bleyseng
post Nov 15 2020, 04:17 PM
Aircooled Baby!
How fast and budget? A 2056 with 120-130hp can be built for $5-6k
Cairo94507
post Nov 15 2020, 04:40 PM
Michael
Bleyseng just nailed it. Go with a 2056 and stock fuel injection with a mild cam and nice exhaust. Reliable, strong and pretty bullet proof. Heat is the enemy of these engines and going large displacement on a 4 is a recipe for engine death unless you spend the money to do it right and keep it cool. (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Nov 15 2020, 05:11 PM
QUOTE(Cairo94507 @ Nov 15 2020, 05:40 PM) *
Thanks guys, car I am considering is a carbed version 1.7. I will make the trip next weekend and bring her home if the rust is not too bad. Can these cases be used for a 2056 kit? I am very new to the 914 world. Been a 356 and 911 guy for many years.
Bleyseng
post Nov 15 2020, 08:46 PM
Aircooled Baby!
QUOTE(930cabman @ Nov 15 2020, 03:11 PM) *
Yes, the cases are the same. The 2.0l crank and rods are different but the same ones sre used in BW Baywindow buses. The 2.0L heads are totally different and the can be bought new from Len@HAM that are set up for HP. If you can find a Djet or ljet set up For Fuel injection thats one way to go. Carbs is another
Tdskip
post Nov 15 2020, 09:05 PM
QUOTE(Bleyseng @ Nov 15 2020, 09:46 PM) *
I thought those are only available at lnengineering now and around $3,850, no?
Bleyseng
post Nov 15 2020, 09:29 PM
Aircooled Baby!
New 2.0L AA casting are reworked by Len with all new parts. Roughly $1700 for a set which I am running myself in my 2056 engine. I have 44x38 valves too
DRPHIL914
post Nov 15 2020, 10:03 PM
Dr. Phil
QUOTE(Bleyseng @ Nov 15 2020, 10:29 PM) *
how much more hp with len’s heads and the 2057 set up with d-jet? i can tell you after my first a/x weekend that while the 914 handed far better than most of the hot hatches there this weekend they best me by 5 sec or so and it has so much to do with the quick acceleration out of the corners, which i was sorely lacking—. very i interested in doing this by next weekend. i can run SCCA heritage , even with the 2056 as long as the case is the original stock case, can’t turbo it.
Bleyseng
post Nov 15 2020, 10:49 PM
Aircooled Baby!
QUOTE(DRPHIL914 @ Nov 15 2020, 08:03 PM) *
I set my car up for AXing and track use in 2004. The 120hp is nice but installing a shorter 3rd and 4th gears made the difference plus being able to rev to 6000 rpms. BUT a 914 in AXing isn’t about acceleration but carrying speed thru the corners. Money spent on suspension upgrades and tires makes a huge improvement
Superhawk996
post Nov 16 2020, 07:35 AM
QUOTE(Bleyseng @ Nov 15 2020, 11:49 PM) *
. . . AXing isn’t about acceleration but carrying speed thru the corners. Money spent on suspension upgrades and tires makes a huge improvement
I used to AX my Miata as SCCA C street (stock) level in the 90s. Had the opportunity to ride with former SCCA Nationals winner driving my car. It was humbling. There was ton's of time left in my car. All about the driver, technique, and maintaining momentum. And that was with my lard (IMG:style_emoticons/default/bootyshake.gif) as dead weight in the car too! 914's are no different.
DRPHIL914
post Nov 16 2020, 08:09 AM
Dr. Phil
QUOTE(Superhawk996 @ Nov 16 2020, 08:35 AM) *
no doubt i have a lot to learn!!! i am sure there is a some more time in the car and a few tweaks to be made . i let an instructor drive the car for a run and he was not used the the long throw of the clutch in a 914, but i watched his line and how he came thru several turns and braking points etc., so then my next run was much faster, inf fact i ran faster than he did, but that is just me knowing my car better than him. if he took it out for 3-4 more runs no doubt he would have knocked off a good 5-6 seconds i am sure. - hey i went out to learn and get a better feel for what the car can do, it’s very tight and well balanced, with the sport bilistein and 205/55-16 on 7” rear and 6” front, it’s super tight. i never slid or lost traction in front, just the rear on a couple tight corners, came in too tight on wrong line, but it comes back fast, i never felt like i was going to spin out or loose it, but i could feel towards the last run i was getting a good feel of how far i could push it. being only 3-4 seconds behind a couple of the mazda’s , bmw and suby in our novice class and looking at the times of the fret class drivers i can see it could be competitive
looking forward to seeing home much i can improve next year with learning how to adjust the suspension etc, like, if i dropped the rear one notch it would add an extra degree of negative camber and i think i could hold those tight corners a bit better.
any other suggestions are welcome !!
VG-914
post Nov 16 2020, 08:14 AM
777AIA
Now-a-days, you need to start keeping an eye on resale value. So many 914‘s has been chopped up and modified, that we are starting to see the purebreds are seeing some real numbers in resale, as they have never seen before. All I ask is that if you pick up at 914 that is stock, you don’t bastardized it too much… Find one that’s already been chopped and do your dirty work! Sorry - but I like ‘em stock. Too much street fun as they are. If I needed some speed, I’d be sitting in a WRX.
DRPHIL914
post Nov 16 2020, 10:49 AM
Dr. Phil
QUOTE(VG-914 @ Nov 16 2020, 09:14 AM) *
great advice for the O.P. and i take it as well., unless it is already too far out there already,
Bleyseng
post Nov 16 2020, 12:53 PM
Aircooled Baby!
QUOTE(VG-914 @ Nov 16 2020, 06:14 AM) *
That's why I like a 2056 w/Djet as it looks totally stock, Sway bars and shocks can help alot in AXing plus bigger Tbars and rear springs.
914_teener
post Nov 16 2020, 01:00 PM
".....I need speed...."
What does this mean? The 914 with a four jug will not be fast but might be quick and nimble.
Like Geoff said you'd have to play with the gear box for it to be really quick. If you want it for the street I'd say stick with the short stroke rods but go big jug....like a 1911 with L-jet.
Forget the carbs...bad idea
My .02 from experience.
PS.
Once you go flat six you'll never look back.
930cabman
post Nov 16 2020, 01:03 PM
QUOTE(DRPHIL914 @ Nov 16 2020, 11:49 AM) *
That has been my objective with restorations for many years. I have done minor modifications (always easily reversible) and always work towards getting close to factory specs. The specimen I am looking at appears generally stock, might even have original paint, but not taken care of for many years.
Bleyseng
post Nov 16 2020, 02:09 PM
Aircooled Baby!
QUOTE(914_teener @ Nov 16 2020, 11:00 AM) *
Just these days a flat six will totally empty your wallet just like a wooden boat.
8 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 23rd November 2026 - 10:58 AM
