> Fasten Belts light
Nacho
post Dec 5 2020, 03:54 PM
Hello
So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts?
Nacho
post Dec 5 2020, 08:46 PM
Any wire harness gurus out there?
Nacho
914_teener
post Dec 5 2020, 09:31 PM
QUOTE(Nacho @ Dec 5 2020, 01:54 PM) *
Hello
Your door switches are worn or not connected correctly assuming you have a 73 or later.
Nacho
post Dec 5 2020, 09:49 PM
QUOTE(914_teener @ Dec 5 2020, 10:31 PM) *
Hello
Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ?
Thanks
Nacho
914_7T3
post Dec 6 2020, 07:34 PM
@nacho
I have extra switches if you need. One of mine was bad. Also if the connectors break and it touches the body, it will also mess up the whole circuit; dome light, buzzer......
914_teener
post Dec 6 2020, 08:46 PM
QUOTE(Nacho @ Dec 5 2020, 07:49 PM) *
Hello
Thanks
Nacho
Pretty sure you can search for wiring diagram. They are all switched grounds. Two are for the buzzer and seatbelt and IIRC the others are for the dome ligjt. Test the switch continuity first with a DVM before the goose chase starts.
Nacho
post Dec 6 2020, 09:54 PM
QUOTE(914_7T3 @ Dec 6 2020, 08:34 PM) *
@nacho
Thanks. I did have a switch that was being a bit of a pain, and I'm not confident its working correctly. I'll give you a buzz.
Thanks
Nacho
post Dec 6 2020, 10:03 PM
QUOTE(914_teener @ Dec 6 2020, 09:46 PM) *
Hello
Thanks
Nacho
Sweet thanks for the help. (IMG:style_emoticons/default/beerchug.gif)
Nacho
r_towle
post Dec 6 2020, 10:44 PM
Custom Member
isn't all the seatbelt garbage wiring underneath the passenger seat?
mine is all removed now (IMG:style_emoticons/default/smile.gif)
mate914
post Dec 7 2020, 07:30 AM
Matt
I'm thinking ground issue....
If ground connections are not good on car, electricity will find its own way to ground.
When that happens things don't work right.
Matt
Maltese Falcon
post Dec 7 2020, 10:24 PM
Simple fix, set the trigger 12v signal (to the bulb) to a hobbs (manifold) switch, set activation at 1 bar boost ! Make sure to belt-up
Nacho
post Dec 9 2020, 10:22 PM
QUOTE(Maltese Falcon @ Dec 7 2020, 11:24 PM) *
(IMG:style_emoticons/default/agree.gif) Why didn't I think of that! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/lol-2.gif)
Nacho
Nacho
post Dec 9 2020, 10:27 PM
So far things are pointing at a bad drivers door switch. Tomorrow I will be swapping the switch out. If that is the problem then I'm one step closer to (IMG:style_emoticons/default/driving.gif)
- Lo-Fi Version Time is now: 25th November 2026 - 02:43 PM
