Full Version: Fasten Belts light
Nacho
Hello
So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts?
Nacho
Any wire harness gurus out there?
Nacho
914_teener
QUOTE(Nacho @ Dec 5 2020, 01:54 PM) *
Hello
Your door switches are worn or not connected correctly assuming you have a 73 or later.
Nacho
QUOTE(914_teener @ Dec 5 2020, 10:31 PM) *
Hello
Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ?
Thanks
Nacho
914_7T3
@nacho
I have extra switches if you need. One of mine was bad. Also if the connectors break and it touches the body, it will also mess up the whole circuit; dome light, buzzer......
914_teener
QUOTE(Nacho @ Dec 5 2020, 07:49 PM) *
Hello
Thanks
Nacho
Pretty sure you can search for wiring diagram. They are all switched grounds. Two are for the buzzer and seatbelt and IIRC the others are for the dome ligjt. Test the switch continuity first with a DVM before the goose chase starts.
Nacho
QUOTE(914_7T3 @ Dec 6 2020, 08:34 PM) *
@nacho
Thanks. I did have a switch that was being a bit of a pain, and I'm not confident its working correctly. I'll give you a buzz.
Thanks
Nacho
QUOTE(914_teener @ Dec 6 2020, 09:46 PM) *
Hello
Thanks
Nacho
Nacho
r_towle
isn't all the seatbelt garbage wiring underneath the passenger seat?
mate914
I'm thinking ground issue....
If ground connections are not good on car, electricity will find its own way to ground.
When that happens things don't work right.
Matt
Maltese Falcon
Simple fix, set the trigger 12v signal (to the bulb) to a hobbs (manifold) switch, set activation at 1 bar boost ! Make sure to belt-up
Nacho
QUOTE(Maltese Falcon @ Dec 7 2020, 11:24 PM) *
Nacho
Nacho
So far things are pointing at a bad drivers door switch. Tomorrow I will be swapping the switch out. If that is the problem then I'm one step closer to driving.gif
