| JamesJ |
Dec 8 2020, 08:54 PM
Member ![]() ![]() Group: Members Posts: 300 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
Hello All,
I have a '74 1.8 car and I recently replaced my old black coil with a new Bosch blue coil. The new coil is a bit smaller in diameter than the black one and does not fit properly in the original coil bracket. The front side of the coil bracket is mounted with a bolt and the back side just hooks under a slot in the fan housing. I prefer not to relocate the coil bracket and have to run different lengths of wires to reach the coil in a new position. I am leaning toward an original look by having my factory coil bracket made smaller to fit the new coil, or place something between the coil and the bracket to create a tight fit that would withstand the heat from the coil but still appear original looking so as to not stand out. The car runs but is parked for now, so I just put a shop rag around the new coil temporarily until I figure out a solution that works. What have other folks done? Any suggestions? Thanks! Attached thumbnail(s) |
| Mike D. |
Dec 8 2020, 09:02 PM
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None
I have done the same thing and used a thick piece of rubber, cut to width of the bracket.
| bdstone914 |
Dec 8 2020, 10:16 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,431 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@jamesj
I have a roll of some 1/16 x 1 cork/rubber gasket material with adhesive backing. Two layers should work. I can include some with the other parts you ate getting. |
| 914sgofast2 |
Dec 8 2020, 10:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Cut a section or two out of an old bicycle tube and put it around the body of the new coil until it is big enough to hold tight in the coil bracket.
| JamesJ |
Dec 8 2020, 10:24 PM
| JamesJ |
Dec 8 2020, 10:26 PM
| Superhawk996 |
Dec 9 2020, 07:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,192 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Anybody have a part number and/or source for this style of bracket that mounts coil to the fan shroud?
I know they are on VW bus but google really hasn't turned up anything for me other aftermarket brackets that aren't the same style. I guess the probable answer is to keep an eye on Samba and/or post a WTB looking for a used one. |
| BillC |
Dec 9 2020, 07:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 763 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
A strip of 16ga aluminum makes a great shim -- place between coil and bracket -- and won't add any insulation around your coil, like rubber or cloth would.
| 914Sixer |
Dec 9 2020, 11:32 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,614 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Use the same piece of rubber that is used in the mount of the rear blower fan.
| rhodyguy |
Dec 9 2020, 12:10 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
100%. (IMG:style_emoticons/default/agree.gif) perfect. The single outlet version fan piece.
| djway |
Dec 9 2020, 12:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
You can also get silicone sheet in various thickness'. It last longer than most of the rubbers available.
| 914sgofast2 |
Dec 9 2020, 12:17 PM
Anybody have a part number and/or source for this style of bracket that mounts coil to the fan shroud? I know they are on VW bus but google really hasn't turned up anything for me other aftermarket brackets that aren't the same style. I guess the probable answer is to keep an eye on Samba and/or post a WTB looking for a used one. Those brackets were used on the VW Bay Window buses with Type 4 engines. From 1973 to 1979 I think. I have been looking for one on the Samba Want Ad site for a while. |
Lo-Fi Version | Time is now: 27th November 2026 - 04:04 AM |
