Correct air fllter for a 74 ? |
bdstone914 |
Dec 15 2020, 11:55 AM
bdstone914 Group: Members Posts: 4,541 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I think the rusty top with the larger nipple at the rear is correct. The powder coated one is from my 73.
The dirty top has an added nipple at the front that is not correct. I think that is for a 74. The 75-76 have a flange at the front for the EGR. But that may only b for CA emissions. @jeffbowlsby Attached thumbnail(s) |
JamesM |
Dec 15 2020, 03:59 PM
Senior Member Group: Members Posts: 1,922 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
The one with the large port is not for a 74 (at least not any 74 I have seen)
That large port is for the later non-crank case valve venting setup that used the larger hose from the oil filer housing. Guessing what you have there is a 75 non-ca/smog pump air filter housing. 74 had the smaller port like the 73 but the straight line pattern on top like the 75. I can grab some pictures later if you need as i have both. I think the rusty top with the larger nipple at the rear is correct. The powder coated one is from my 73. The dirty top has an added nipple at the front that is not correct. I think that is for a 74. The 75-76 have a flange at the front for the EGR. But that may only b for CA emissions. @jeffbowlsby |
JeffBowlsby |
Dec 15 2020, 04:25 PM
914 Wiring Harnesses Group: Members Posts: 8,548 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
914Sixer |
Dec 15 2020, 05:16 PM
914 Guru Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Maybe 1976 912E with AFC?
JeffBowlsby |
Dec 15 2020, 06:41 PM
912E is L-Jet.
Lo-Fi Version | Time is now: 15th June 2024 - 01:21 PM |
